PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old Apr 8, 2013 | 06:38 AM
  #2631
Prokaw875's Avatar
Can p-tuning please chime in if a HTA 86 with tial housing obviously will fit on the kit?
Old Apr 8, 2013 | 07:17 AM
  #2632
miguel329's Avatar
Pm mrc he is quick to reply
Sent from my SPH-L710 using Tapatalk 2
Old Apr 8, 2013 | 09:04 AM
  #2633
MrC@PTUNING's Avatar
If you're referring to the FP GT3586R turbo with tial housing, I believe externally it is identically to a standard GT3586R/GTX3586R with the exception of their own billet compressor wheel. What this means is that it also uses the same CHRA and compressor housing off a GT35R which will fit our kit since our kit was designed to mount either a GT/GTX30R or GT/GTX35R turbo.
So why is everyone trying to make 700whp? The S is already a handful to drive through the twisty with a base GT30R and 400+ DD whp. But I guess for drag racing, you can never have enough power. You guys are so greedy
MrC
Old Apr 8, 2013 | 11:27 AM
  #2634
miguel329's Avatar
Originally Posted by MrC@PTUNING
Originally Posted by miguel329' timestamp='1365434244' post='22459107
[quote name='Prokaw875' timestamp='1365431909' post='22458982']
So why is everyone trying to make 700whp? The S is already a handful to drive through the twisty withh a base GT30R and 400+ DD whp. But I guess for drag racing, you can never have enough power. You guys are so greedy
MrC
[/quote]
Drag racing
Old Apr 8, 2013 | 05:46 PM
  #2635
Prokaw875's Avatar
MrC
[/quote]
Great! Thanks! And to answer your question it's for drag... Street car... I have to many friends with 600, 700, 800whp street driven cars! Ugh... Lol thanks for the help!
Old Apr 10, 2013 | 02:48 AM
  #2636
ArchAngel2K's Avatar
Ok so I was able to get boost under control with the new prototype restrictor. We were able to do a final tune at 17psi 525whp mustang dyno 0 knock voltage, and pump gas. Only thing I suggest for faster spool is put in a 7lb inner spring in the WG but as far as getting boost under control with a gt3582r on stock internals the restrictor works perfectly. I approve mass production lol. So all this being said I'm glad I can move on from this. I am getting out of the turbo game. I enjoyed every second of having all this power but I need to move on to my true passion which is competitive karting. So chase race here I come. PTuning guys thank you for all your help.
Old Apr 10, 2013 | 07:35 AM
  #2637
Forcedbird's Avatar
Originally Posted by adambarkley
Originally Posted by Forcedbird' timestamp='1364998217' post='22447997
[quote name='indi00' timestamp='1364997401' post='22447960']
No creep issue even without the disc here. Boosting to 17psi at redline 10K redline. Run wastegate for sure to eliminate probs.
What do you mean when you are saying: "Run wastegate for sure to eliminate probs."?
I am running the Turbosmart wastegate that came with the PTuning kit but I have it recirculated back into the exhaust.
I'm also running with no restrictor disc, wastegate dumps to atmosphere. I don't have any boost creep problems and can easily control boost with a MAC valve on the wastegate. I'm convinced that dumping to atmosphere gives you much better control of creep.
On a related note, I need to refresh my memory about exactly what point the wastegate is designed to recirculate into the exhaust system. If my memory serves, the Ptuning recirc tube routes the gas back into the downpipe UPSTREAM of the restricting disc (on the manifold side of the disc rather than on the muffler side of the disc). Can anyone confirm this? If that's the case, the restrictor disc would be restricting both the main exhaust path and also the wastegate bypass path. It still likely provides some degree of control in this arrangement (due to the pressure drop of the exhaust turbine), but I'm not convinced the restrictor disc would help to effectively manage creep in this case. My opinion is that you get the best wastegate control by ensuring the lowest possible restriction of the wasted exhaust gasses. A short section of tube dumping to atmosphere is about as low restriction as possible Second best would be to recirculate into the exhaust DOWNSTREAM of the restricting disc. Thoughts anyone?
[/quote]
It makes sense to me that dumping the atmosphere will control creep better. I may have to try that route eventually.
I don't want to mess with my boost because everything has been tuned by PTuning.
You are correct, the recirc tube does route the WG gas into the exhaust UPSTREAM of the restricting disc.
I do agree with you that dumping into the exhaust downstream of the restricting disc will help control boost better. Since that isn't an option with this kit dumping to the atmosphere is the only choice.
With the warmer weather we have been having here in PA lately, I haven't been experiencing any creep issues w/the test disc installed. I feel like it could also be in my tune. When I got tuned it was in 90 degree weather, no restricting disc was needed with no creep issues.
Problem for me is that in the future I want to get into HPDE's. I should be OK doing these in the summer but as the temps get lower the creep will come back even with the test disc. That's a problem on the track.
Talking to others I think my best bet would be to change to dump to atmosphere wastegate and (in spring or fall) remove/install various size restricting discs and/or change modify my tune for cooler weather.
Does anyone run a separate tune for the summer and the winter?
I hope that PTuning can chime in, I'd like to see what they think.
Old Apr 13, 2013 | 02:21 PM
  #2638
sata3000's Avatar
Blah...found a present under the hood today. Pipe coming off the turbo going to the intercooler. I guess my pipes shifted and this one began to touch the manifold.
Sent from my Galaxy S II using Tapatalk
Attached Thumbnails PTUNING S2000 Turbo System (Pics, Dyno, Pricing)-uploadfromtaptalk1365891640620.jpg
Old Apr 13, 2013 | 03:40 PM
  #2639
herecomesboost's Avatar
Yikes!
Old Apr 13, 2013 | 06:58 PM
  #2640
miguel329's Avatar
Damn can't say I ever seen that before..
