PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old Apr 2, 2013 | 12:56 PM
  #2611
Forcedbird's Avatar
Originally Posted by ArchAngel2K
I cannot control boost creep. I have the 2.25 disk in and still spiking to 19 and putting down 570 on pump gas stock internals. I don't know what else to do
Contact PTuning, they should be able to help you out with that. They made me a test disc that is so far controlling my boost creep issue in this cold weather. In the summer I am going to remove the disc because I never had creep issues in warmer temps.
I hope that you have boost cut set in your EMS or you may do some engine damage.
Old Apr 2, 2013 | 02:24 PM
  #2612
ArchAngel2K's Avatar
Ya they sent me a prototype as well currently testing it. My cut is at 20lbs
Old Apr 2, 2013 | 02:25 PM
  #2613
How are your results so far
Old Apr 3, 2013 | 05:12 AM
  #2614
Forcedbird's Avatar
I hit boost cut again last night with the test disc installed .
ArchAngel2k, do you have a link to your setup? Stock head gasket? Open or recirculated dump?
I have a recirculated dump.......and have been told that may be contributing to the creep issues.
Are you creeping in warmer temps?
Old Apr 3, 2013 | 05:56 AM
  #2615
indi00's Avatar
No creep issue even without the disc here. Boosting to 17psi at redline 10K redline. Run wastegate for sure to eliminate probs.
Old Apr 3, 2013 | 06:10 AM
  #2616
Forcedbird's Avatar
What do you mean when you are saying: "Run wastegate for sure to eliminate probs."?
I am running the Turbosmart wastegate that came with the PTuning kit but I have it recirculated back into the exhaust.
Old Apr 3, 2013 | 06:14 AM
  #2617
sata3000's Avatar
I have open dump and do not experience boost creep
  #2618
Forcedbird's Avatar
Do you guys think that having my car tuned in the middle of the summer may be contributing to the creeping issues?
Old Apr 3, 2013 | 09:43 AM
  #2619
You guys are saying you are not having these issues but what turbo are you running. I'm on the 3582
Old Apr 3, 2013 | 09:46 AM
  #2620
Forcedbird my set up is simply stock bottom end dual springs with a 35r stock head gasket
