Question about intake for inline pro turbo
Old Apr 21, 2009 | 07:32 PM
RangOs2000's Avatar
Default Question about intake for inline pro turbo
Is it ok that the intake is smaller than the actual inlet of the turbo? My shop said it would be ok, but i am not sure. I did see another set up on the board where they said the smaller piping didnt lose power, but i just want to make sure. Also does it matter if the filter is foam vs. something like the aem dry flow.
Here are pics for reference:
Thanks in Advance
Old Apr 21, 2009 | 07:41 PM
nightcrawler7188's Avatar
once it's not toooo much smaller i would THINK it would be fine...in theory shouldn't the turbo pull as much air as it needs anyway?
Old Apr 21, 2009 | 07:54 PM
RangOs2000's Avatar
I think its like 3in vs 2.5in. I Think your right about only pulling as much as it needs. I really want to make sure its ok though
Old Apr 21, 2009 | 10:19 PM
Spec_Ops2087's Avatar
Your probably loosing like .5hp, I wouldn't worry about it
Old Apr 22, 2009 | 04:04 AM
Revenge's Avatar
Are you using your old greddy one? Thats how mine is set, but JE said I may want to change it if I start upping the boost but at 9 psi he did not think it was a big deal. You could just run a coupler to a filter. I got a used inline pro one for my car.
Old Apr 22, 2009 | 06:01 AM
RangOs2000's Avatar
Yah i am using the old greddy one, i think i may rig something up. What do u guys do with the 2 hoses attached to the intake arm. I know one of them you can just put a filter on the valve cover, what about the second one?
Old Apr 22, 2009 | 06:26 AM
rob!'s Avatar
just buy a cheap intake from pep boys 3" with a 45 degree bend and just put a good filter on it.
Old Apr 22, 2009 | 07:56 AM
RangOs2000's Avatar
^^ Probably what im gonna do, There is two lines running to the intake arm, what do you do with those?
alanpikku
Jun 17, 2011 11:37 AM
mrscbw
Jul 6, 2008 01:48 AM
asarraf_xz
Jun 20, 2006 02:52 PM
AustinS2k2003
Jun 25, 2003 01:34 PM
