A question of timing..
Old Sep 15, 2005 | 01:35 PM
MB's Avatar
MB
Member
Default A question of timing..
Hi all,
Up to what boost can the standard ECU, with FMU keep the timing in check? I imagine the ECU has a limited range that it can advance, does anyone know what this is and proven it on a dyno?
I will be installing mine soon and want to stick with the FMU for a while, and concerned about ignition timing.
Most interested.
MB
Old Sep 15, 2005 | 02:59 PM
Slows2k's Avatar
The timing controller from Vortech has it's own internal map sensor, and is prgrammed from Vortech. The map supplied pulls under 3deg total timing retard.
It can be reprogrammed if you have the R4 software from Split Second.
The OEM ECU operates normally with the Timing controller installed. The controller sends an offset crank position input signal to get the PCM to retard the timing. The PCM still thinks it is running as much advance as possible.
I had to pull an additional 3deg accross the map to get my car to not detonate on oxygenated winter fuels, in the 4-5K rpm range.
Old Sep 18, 2005 | 12:36 PM
MB's Avatar
MB
Member
Great info, thanks!
MB
chainsaw1968
Mar 2, 2013 05:21 PM
dwedge
Dec 4, 2007 06:02 PM
folex187
Oct 4, 2005 10:10 PM
MB
Sep 30, 2005 11:15 AM
MechaGodzilla
Feb 25, 2003 08:56 AM
