MAP question
Old Sep 30, 2005 | 09:47 AM
MB's Avatar
MB
Member
Default MAP question
Hi,
Im going to be fitting a Vortech S/C and using the FMU instead of an aftermarket ECU.
The MAP voltage is 0-5v but whats its range? Can it read +ve boost or does the FMU fiddle this in some way?
Reason I ask is that im using a PLX wideband which has input for boost, using the MAP signal. It uses a 0-5v scale so just wondering how this will work when there's 7psi going through it, in terms of the voltage output?
MB
Old Sep 30, 2005 | 10:10 AM
folex187's Avatar
Our MAP reads boost that is why you have to use the box that vortech/comptech gives you to limit the amount of voltage the ECU sees. I think the limit for the stock MAP is 11psi but I could be wrong.
Old Sep 30, 2005 | 10:24 AM
MB's Avatar
MB
Member
Thanks.
I recall it being able to read 11 psi, which would mean that would prob be 5v max.
Does anyone definately know the 0-5v scale of the MAP then? I presume its linear. If I know that, I can set up the boost relationship for the MAP on the 0-v scale of the PLX.
MB
Old Sep 30, 2005 | 11:15 AM
MB's Avatar
MB
Member
Found it
min map is 0.32v @ -13.9 psi
Max map is 4.84v @ 10.94 psi
MB
seansniper
Oct 3, 2012 11:56 PM
Cody Strife
Jun 16, 2011 09:41 AM
S2Kart
Apr 2, 2008 05:37 AM
530s2k
Nov 26, 2005 08:06 AM
Sideways
Oct 8, 2004 09:03 AM
