R200 Diff Kit (300zx diff conversion)
Old Feb 9, 2011 | 03:30 PM
dagle's Avatar
Default R200 Diff Kit (300zx diff conversion)
I've been getting mixed search results and I was wondering if the 300zx turbo R230 would work or not? I've found one for 50$ from an importer (JDM scrapyard car). After a few searches, I found someone said that the NA and turbo differentials are identical in exterior dimensions ?
Couldn't find a definitive answer so I figured I'd ask here. Can the R230 differential from a turbo 300zx be used with the InlinePRO differential kit?
Thanks in advance,
Silas
Edit*
Old Feb 9, 2011 | 04:06 PM
Alloy Craft's Avatar
Former Sponsor
I beleive the R200 comes out of the NA 300zx, I think the turbo version has the R230.
Old Feb 9, 2011 | 04:50 PM
dagle's Avatar
Oops you're right, but would it work?
nevermind, got my answer on google. it's bigger
Old Feb 10, 2011 | 09:40 AM
B5254T4's Avatar
Bigger but too big? Would be nice to know.
Old Feb 10, 2011 | 02:32 PM
dagle's Avatar
Well I was assuming that since it's bigger, it'd throw off the mounting of the diff for the kit. Can't find the thread that was in regards to 300zx's swapping diffs, but they swap the complete subframe. I would imagine that if the differentials had the same external dimensions that they would simply swap the differentials. Figured for the 100-200$ difference I'll just go with what the kit was designed for.
couple posts down there's some info on the topic:
https://www.s2ki.com/forums/index.ph...ic=740578&st=0
Old Feb 11, 2011 | 10:07 AM
boostedf22c's Avatar
You can't use the R230 in place of the R200.
Not as a direct swap anyways.
beefystud
Feb 21, 2017 08:01 AM
s2mmkay
Aug 27, 2009 03:53 PM
SPECIAL-OPS-S2K
Mar 16, 2008 07:21 AM
