RC 750's
Old Sep 1, 2010 | 11:17 PM
DBXFX's Avatar
Default RC 750's
I have some used rc750's that im installing can anyone tell me which locations need orings. Ive read i can buy them from home depot. Any source of the legit ones? the previous owner has them all different/ ripped. also is there some kind of SPACER that i have to use? I dont think i have any.
Pic:
what numbered locations have an oring or spacer.
Old Sep 2, 2010 | 04:02 AM
Dan1987's Avatar
3 & 2 I believe for the pre dbw
Old Sep 2, 2010 | 04:05 AM
ap1tuner's Avatar
Space 2 uses the same green o ring that's on it. And space 3 uses a rubber spacer (injector seal). The green o ring is pretty easy to find but I had to go to honda to get the correct injector seal for the bottom of the injector. They r only 6 bucks at honda so not bad. And that's all u shud need.
Old Sep 2, 2010 | 04:08 AM
ap1tuner's Avatar
Also, you might need to takke a dremmell and bore out the inside of the bottom spacer when you get them. This keeps them from being squeezed out and broken when entering the port of the manifold where they sit. If you don't do that then there is a chance the injector could bust the seal
s2konroids
Apr 18, 2012 09:42 AM
s2konroids
Apr 18, 2012 12:59 AM
erikvanden
May 30, 2011 11:12 AM
hondabim
Dec 4, 2008 05:51 AM
rick bailey
Nov 9, 2005 01:21 PM
