Rebuild?
I've revised my budget for the rebuild. I don't plan on reassembling it as is. To do so would be morally offensive to what it is.
Option 2:
Have head inspected and tanked: 80.00
New OEM Head Gasket: 55.00
Reuse Head Bolts: FREE!
New Spark Plugs: 40.00
New OEM Piston Set B: 165.00
New OEM Rings Set: 35.00
Honing/Polishing Block: 150.00
Investigate Aftercooler Situation: FREE!
Upgraded Clutch: 500.00
Test Pipe: 100.00
~1150.00
Any thoughs on the ignition timing? For honing I should be able to stick with the same size piston but I'm wondering if it's worth the effort to replace the conn rod pins/clips and con rod and crankshaft bearings while I'm down there. (So many sizes gah!) Engine has ~75k miles on it with about 30k of those under the comptech.
Option 2:
Test Pipe: 100.00
~1150.00
^^^Educate yourself on water/meth injection kits if you haven't already, on your set up/boost level you wont have to worry about running too much timing or having detonation issues if you run this stuff, you shouldn't anyway at your level, you obviously had an issue, but if you continue to have issues the water/meth will be a safety barrier protecting your motor. I run 9psi on the stock timing map, stock everything for that matter. Due to that I also make as much power as someone running a CT kit at 10-11psi with standard timing retard for that level without water/meth injection. God, most kits are only $300-$500 and you can hook it up in a couple hours on a Saturday afternoon. Tuning it is simple as long as you have some basic understanding of what your affecting.
I'll definitely look into it. I have my 3.0" pulley in hand and am investigating ordering the above items. I was contemplating meth injection before this happened. The only thing holding me back was that a 5 gallon tank in the trunk might eliminate my ability to carry golf clubs.
I think I'm going to go with the SOS clutch unless anyone thinks sourcing a newer ACT pressure plate and getting an OEM disk is better. I'm aiming to eventually push around 380whp or more.
Btw, I hate snow. :/
I would definitely run meth with the 3" pulley.
Alrighty. engine is out and on a stand now. I've ordered OEM pistons and rings as well as a head gasket. I'm planning to go with the SOS Comp Stage 2 clutch. Anyone have any recommendations on meth kit? AEM seems to have a nice setup.
Also, a clarification is in order. The water temp gage I had was attached to the engine coolant lines at the thermostat. It was not an intercooler water temp gage as I though. I may consider getting an EGT gage or boost gage instead as I installed modifry's little device for the EMS to get my factory gage working again.
EVAN_In_A_SPA
Feb 11, 2010 05:07 PM
