Rebuilding Turbo Set-up
Old Aug 24, 2010 | 12:27 PM
Turbost00k's Avatar
Default Rebuilding Turbo Set-up
So....Ive been running inlinepro's turbo setup for over a year now and love it.
the car made 440whp on 14psi with a conservative tune by Jeff Evans and has been running flawlessly since day one.
I have hit a crossroads since my car started "getting hot" a couple weeks ago.
The A/c system was overhauled(new condensor/compressor) and the coolant system was not bled properly, causing over heating(once) and has likely destroyed some portion of the HG.
I pulled the motor this weekend and am planning my rebuild in the next week.
I don;t want to get another 3mm IP HG(as I have been reading stock HG is the way to go)
The car has ARP head studs and completely stock internals. With the motor apart, I want to make the right changes, before I put it back in the car.
Im thinking stock/OEM HG and CP 9:1 pistons and manley rods as my only internal mods.
I was also going to redo the cooling system(rad./etc.) at this time.
What are you suggestions, thoughts, experiences, w/e. with this situation and how would you handle it? What kind of costs should I look for when re-balancing the engine with the new rod/piston setup and machining the deck/the head and rebuilding the longblock?
Old Aug 24, 2010 | 01:10 PM
teamvalorracing's Avatar
use the search option. this info have been beat to death over and over.
Old Aug 24, 2010 | 01:53 PM
passmans2kny's Avatar
u cant use the cp pistons with the stock sleeves, mahle came out with some frm friendly pistons
Old Aug 25, 2010 | 12:31 PM
bluemetals2k's Avatar
save yourself some money and get another 3mm headgasket
Old Aug 25, 2010 | 01:59 PM
spectacle's Avatar
Old Aug 25, 2010 | 02:43 PM
Turbost00k's Avatar
Originally Posted by spectacle,Aug 25 2010, 01:59 PM
as much as i agree with you and as much as I don't want to, that is what I did
was looking at $5K for parts and balancing/building the engine again.
decided to just go 3MM again and NOT have any clowns who don;t what their doing touch it again
ERL_S2000
Apr 26, 2008 05:19 PM
slammo
Feb 24, 2006 06:09 PM
gomarlins3
Feb 17, 2006 04:07 AM
SuzukaRod
Nov 16, 2005 01:02 PM
