removing comptech sc
Old Oct 29, 2007 | 01:21 PM
kylemonster85's Avatar
Default removing comptech sc
im about to remove my sc and sell it but i was wondering how hard is it to take of the sc and get it back to stock running the onlything im worried about is the oil line in the oil pan and the comptech fmu so how do i get it back to stock
thanks
Old Oct 29, 2007 | 02:12 PM
73Zero's Avatar
In regards to the oil return line, all you're going to need is the original oil drain plug. Basically, the Comptech S/C oil drain line replaces the OEM plug. If you're removing the blower (and the oil line/fitting), then you just replace it with the OEM plug.
As for the FPR, I'm sure somebody else can chime in...when I installed mine, my uncle was taking care of that portion of the install, so I haven't got a clue about it.
Old Oct 29, 2007 | 04:13 PM
CourageOO7's Avatar
It's pretty simple...there's a stainless steel line that goes from the fuel rail to the FPR. Disconnect that line on the fuel rail side and unbolt the black harness thingy that the line plugs into on the rail.
Install the stock FPR and take the rubber lines from the bottom and the side of the Comptech FPR and connect them to the stock FPR using the correct orientation (I think the bottom connects to the stock FPR elbow and the side connects to the top but I'm not POSITIVE).
Voila. You're done.
Old Oct 29, 2007 | 05:06 PM
how much would a stock fpr be i need a new one
Old Oct 29, 2007 | 06:23 PM
CourageOO7's Avatar
Just find someone who's parting their car out and get that one. It should cost you about $30 shipped or so...
Old Oct 29, 2007 | 07:09 PM
would something of ebay like this work
http://cgi.ebay.com/ebaymotors/BLUE-FUEL-P...sspagenameZWDVW
Old Oct 29, 2007 | 07:18 PM
73Zero's Avatar
Don't even bother with those cheaply made pieces of garbage.
You're better off just getting a used or new OEM FPR. A used one can run you (as stated above) about 30-40 bucks. A new OEM part will run about 65-90 bucks.
Check it out (#6): http://www.hondaautomotiveparts.com/auto/j...INTAKE+MANIFOLD
JDM S2000
Dec 21, 2006 04:04 PM
mwd473
Oct 1, 2006 06:03 PM
ChuckS2k
Apr 20, 2006 08:36 AM
r_duff
Sep 7, 2005 02:06 PM
jdmdohcpower
Oct 31, 2004 04:45 PM
