retarding timing
Old Apr 15, 2012 | 03:27 AM
s2knoob89's Avatar
Originally Posted by s2konroids
Stock sc should retard timing really I've found there is power to be gained.
Old Apr 15, 2012 | 05:48 AM
1SlowSi's Avatar
Originally Posted by s2knoob89
Lol....yeahhh
Old Apr 15, 2012 | 06:36 AM
S2SEXY's Avatar
this is why i asked the question
Old Apr 15, 2012 | 06:46 AM
s2konroids's Avatar
Sorry have been clearer.
A stock SC e.g CTSC running stock ECU with stock pulley (5.5psi) (or other SC's) which folk have run is too advanced using stock ECU timing.
Since the OP's answer is about the GEMU its relevant, e.g not using a standalone.
As said mine is -0.5 psi of boost and slightly more right at the top end.
Old Apr 15, 2012 | 08:13 AM
o'malley_808's Avatar
Originally Posted by camuman
I was taught that timing should climb to redline at wot. Not peak then drop. Also I would pull 1.25 per psi of boost and then start to climb from there. I run 14 psi and my map runs 14 degrees at peak rpm peak boost. Pump gas
Is your ignition timing based on load/rpm? I'm just comparing a few of my old cal files from my old setups that my previous tuner did now that I am becoming more involved in the tuning aspect and basically tuned my last setup with a tuner.
My old cal files are adjusted to peak then drop all building up timing to 0 psi then dropping from there.
I would be interested to see how your timing table looks! Post a pic if you get a chance!
Old Apr 15, 2012 | 08:18 AM
GuardsRed's Avatar
Good info right here!
Old Apr 15, 2012 | 08:19 AM
Here is a really old file for comparison sake. I didn't tune the car and this setup was about 4 years ago with an UR kit running 9psi on a stock compression F22.
Here is the S2000 Startup cal for comparison
Here is my UR 9psi timiing table
Old Apr 15, 2012 | 09:11 AM
S2SEXY's Avatar
o'malley has it set up as camuman said.lower timing at 5k then at 9k.
my timing with a ctsc about 11psi
6500 29degrees 7.8psi
7200 28/8.6
7500 27/9
8000 23/9.6
8300 19/10.0
9000 19/11
Old Apr 15, 2012 | 09:39 AM
S2SEXY's Avatar
Originally Posted by 3en
If you are tuning on a dyno it wont be too hard to set up timing.
I dont know what kit you are running, but you want to start out conservatively.
Make sure you have your AFRs close to where you want them to be
I would set it less then 20* for most of the WOT section when you start building boost.
Do your pull. If you see any know major knock or lean conditions let off and add fuel/retard timing to that section. You shouldnt see much if any if with timing retarded this much.
Start going through and adding timing until you stop gaining torque. If you keep gaining torque but also start getting knock back it off a couple of degrees and leave it there, that about as good as youre going to get it.
This is how I was taught and do it. A lot of people will tell you to keep adding timing until you get knock then back it off. I dont like this approach and feel its a little more dangerous. Reason being if you are making the most torque at say 18* and you are getting knock at 26* so you back it off to 24*. Now you only have a 2* safety net instead of 8* safety net.
Good luck and we all had to start somewhere with questions.
thank you
japhethwar
Nov 20, 2011 02:47 PM
rikhemi
Aug 26, 2011 09:31 AM
Dan1987
Aug 30, 2010 05:28 PM
EK9MAX
Jun 28, 2010 03:59 PM
beroznikmal
Mar 27, 2004 05:59 PM
