Revhard log with 6262 clearance
Old Sep 22, 2010 | 05:51 PM
purekoryo's Avatar
Default Revhard log with 6262 clearance
Will the revhard log manifold with precision 6262 fit without grinding or modifications?
Old Sep 22, 2010 | 07:14 PM
s_d2k's Avatar
no.
you have to notch the frame.
Old Sep 22, 2010 | 08:30 PM
Spoolin's Avatar
Originally Posted by s_d2k,Sep 22 2010, 10:14 PM
no.
Not if you go with the E compressor cover I believe.
Old Sep 22, 2010 | 08:56 PM
s_d2k's Avatar
maybe ,my answer was for the regular compressor a/r .
i had the same problem with a revhard mani and a garrett 60-1 that also have a .70 compressor a/r.
Old Sep 23, 2010 | 02:09 AM
riceball777's Avatar
no you cannot run a S compressor cover (.70ar) with most bottom mount log manifold such as the rev hard and inlinepro manifolds.
people that run these manifold with bigger turbos like the 6262 or gt35r have to eith notch the frame or run the smaller E compressor cover (.60ar)
Old Sep 23, 2010 | 04:20 AM
s_d2k's Avatar
i did something else.
my mechanic built for me this adapter plate that moves the turbo about an inch towards the block and i didnt notch the frame and had zero problems with it.
Old Sep 23, 2010 | 09:47 AM
MTZ's Avatar
MTZ
That's awesome thinking from your mechanic is your drain too short now though ?
Old Sep 23, 2010 | 09:57 AM
JDMallmotorAP1's Avatar
any over bigger then .60 a/r cover on a revhard mani you'll have to notch the frame
Old Sep 23, 2010 | 11:32 AM
s_d2k's Avatar
no the oil drain is ok.
Old Sep 23, 2010 | 08:30 PM
dc2-2-ap1's Avatar
do you have any more pics of the adapter plate.
Corey Maurer
Nov 26, 2011 10:44 AM
riceball777
Nov 6, 2010 09:02 PM
batikan
May 27, 2009 04:04 PM
TelosHedge
Nov 28, 2008 06:45 AM
