Ring gap on stock block
Old Dec 14, 2018 | 08:10 AM
Jdmjeckjeck's Avatar
Default Ring gap on stock block
So I had my f22 blow a ring and I have a spare f20 I'm going to drop in a friend seems to think I need to gap my rings I'm going for 500 whp but I'm not going to push over 19lbs so where ever I land with only pushing max 19lbs is where I land my bottom end is completely stock do I need to gap my rings is the question
Old Dec 14, 2018 | 08:28 AM
riceball777's Avatar
I’m at 135,000 miles on the stock f20 block and at 588whp and been turbo since 70,000 miles. I think your fine with the stock block.
Old Dec 14, 2018 | 09:23 AM
With no extra ring gap correct?
Old Dec 14, 2018 | 11:10 AM
correct
100% stock untouched block.
Old Dec 14, 2018 | 11:19 AM
noodels's Avatar
The OEM pistons are made of a very special alloy
Old Dec 14, 2018 | 05:21 PM
Charper732's Avatar
For every "my block is stock and its fine" there is a trashed block out there.
last customer block I tore down after it was boosted, the rings fell into several peices because ends touched.
oem spec is stupid tight. Personally, I would double the gap on an oem rebuild. Blow by wont be an issue.
For reference, the last f24 i built for 800hp I used CP pistons with a gap of .022" top and .028" second
Old Dec 14, 2018 | 05:47 PM
s2000ellier's Avatar
top ring gap has a service limit up to .024 inches anyway
umair
Jan 13, 2019 04:50 PM
louis123428
Feb 11, 2013 11:27 AM
GDM S2K
South Florida
Oct 2, 2007 09:30 AM
