Rod Knock - Should I build my engine?
Old Aug 4, 2013 | 06:29 PM
Pinky's Avatar
My thought is rod knock. See if you can put your ear close to the intake runners and see if one runner is louder than another or if its front or rear of the engine.
If you are AP1 and early '02 or older and didn't upgrade your banjo bolts likely you spun a bearing!
I did that with my car and if it sounds very metallic like a screwdriver hitting metal and it doesn't go away at any RPM, gets louder on accel and almost goes away when decelerating(engine braking) then it's def spun bearing IMO. When you decel it takes the load off the bearing and the knock virtually disappears! Under load it gets louder.
Old Aug 4, 2013 | 07:19 PM
UCF_S2K's Avatar
Thanks for the input. Spun bearing was actually my first thought as well.
I have 2000 AP1. I put a whole another quart of oil in my engine today and it is barely at the low mark
Old Aug 4, 2013 | 09:31 PM
bobbyrandolph440's Avatar
What's this up grade your talking about never hurd of it and I have a early 02 my self
Sent from my VS870 4G using Tapatalk 2
Old Aug 5, 2013 | 06:00 AM
Pinky's Avatar
Just do some hunting on Banjo Bolts S2000. You can even find the ENGINE NUMBER(not vin number) that will give you an idea if yours was made after they changed the bolts. They are tied into the oil sprayers.(more oil flow) I found the engine number on my replacement '02 engine and found I was about 700 engines after the earliest switch over number found. Billman250 is a screen name to search on this too as he posted in a thread on this topic.
https://www.s2ki.com/s2000/topic/884...-oil-sprayers/
Old Aug 6, 2013 | 04:01 PM
UCF_S2K's Avatar
Bump
Anyone have any idea what the noise is? My best guess is rod knock.
I'm undecided if I want to rebuild my current engine with a few new pieces or if I should just buy a used block and build that one. Anyone have any input or experiences with either of those?
dlq04
Jul 3, 2012 08:11 AM
wazpe
Apr 25, 2011 09:45 PM
Blurter
Car Talk - Non S2000
Jul 7, 2009 06:04 AM
rai
Feb 24, 2007 07:48 PM
LdoubleE
Sep 16, 2006 08:45 PM
