Rotrex C38 Kraftwerks log
You can run on the stock MAP sensor and replace it later. Did it myself for two weeks. I swapped to the 4-bar MAP sensor just three days ago. Just working through cogged belt tension issues now.
Great to know. Did you have to tweak the cal file to account for a different map sensor?
I had the calibration set on the stock map sensor. After I installed the 4-bar map sensor, I changed the calibration file to the proper sensor.
New kit from Kraftwerks. There are many things different from the old kit:
*larger Rotrex
*cog belt design
*AEM EMS v2 for AP1
*no engine oil cooler (Laminova on the old kit)
*larger injectors
*higher output fuel pump
*larger Rotrex
*cog belt design
*AEM EMS v2 for AP1
*larger injectors
I'd say the cog drive will need to prove itself. There are ups and downs with both designs. I leaned towards the cog design to limit slip of course but it remains to be seen how much beating the C38 can take as a result. In theory it should hold up unless you rev the thing with no load.
It seems that I am not the only one missing parts in these kits and the missing items seem to be similar. To aid future owners of the kit with a check off list I am including a full listing of parts below. This way you won't have the car sitting on blocks for weeks like I am.
Complete list, without bolts, nuts and washers, of parts that should be in the kit. Blue coded items are the ones that I was missing in the box, red coded items are parts that do not match. Fuel injectors are too large for the rail, "T" fitting is too large for the OEM hose.
Kraftwerks 00-03 Honda S2000 Supercharger System w/ AEM V2: 150-05-2003
Coolant hose splice
Crank pulley adapter
Crank pulley bolt
Idler pulley stud
Idler pulley spacer
Timing cover bracket
Supercharger plate
The Rotrex itself
The Rotrex 80mm pulley
Cog belt
3 idler pulleys with spacers
Tensioner bracket
Top supercharger bracket/cover
4 banjo fittings
Rotrex reservoir
Spacer and two brackets for reservoir installation
Rotrex cooler
Rotrex cooler bracket
A/C condenser spacer
Rotrex oil filter
P clamp for Rotrex oil filter
4 oil lines with two spring clips for each
Rotrex traction oil
Intercooler
2 intercooler mounting brackets
3 charge pipes
5 large couplers with two clamps each (missing: throttle body coupler)
Bypass valve
Rotrex air filter
3 hoses to bypass valve with 4 clamps for the larger hoses
FPR vacuum line "T" fitting
Temp sensor block off plug
Breather hose
4 bar map sensor
Fuel pump with fuel filter
4 injectors
AEM EMS
Calibration file
Air injection filter
Air injection spacer
2 air injection splice connectors/extenders
Coolant hose splice
Crank pulley bolt
Idler pulley stud
Idler pulley spacer
Supercharger plate
The Rotrex itself
Cog belt
Tensioner bracket
4 banjo fittings
Rotrex reservoir
Rotrex cooler
Rotrex oil filter
Rotrex traction oil
Intercooler
3 charge pipes
Bypass valve
Rotrex air filter
Breather hose
4 bar map sensor
4 injectors
AEM EMS
Calibration file
