Running with out the belt?
Old Mar 12, 2008 | 06:47 PM
CD7SirAccord's Avatar
Originally Posted by Jano,Mar 12 2008, 07:10 PM
I must be stupid tonight. I re-read this 3x! If this is a stock Comptech kit with the Comptech supplied FPR, what exactly are you going to have tuned? There's no need unless the kit is used and the FPR has been altered or adjusted in some way.
Since the stock kit relies entirely an ESM to mask boost and a FPR to push more fuel, the only adjustment available is more or less fuel pressure.
If I'm not understanding and you aren't going with a fuel delivery setup that is standard for the kit, I would not run the belt. Why "guess" at what fuel pressure should be for 300 miles? When I was at stock boost, fuel pressure at the rail varied from 35-40psi at idle to easily over 80psi at rpm. Again, if this isn't a standard kit in some way, then install it, drive and hope for the best seems like a bad idea....if it is a standard kit the trip to the tuner is optional. Not a bad idea for a double check of A/F's but not necessary.
I'm probably just being overly cautious, so I apologize. I just wanted to get to a dyno, just to be on the safe side and make sure I'm not overly rich or dangerously lean. I live in Colorado so I'm about 5400ft above sea level, if anything it'd probably result in a rich fuel condition if the FPR was set at sea level or close to. I'm probably just worrying too much. Thanks for all the help and advice.
ceophlo
Jan 24, 2019 06:18 PM
TheBigShow
Aug 16, 2009 09:22 PM
S2KKC
May 13, 2008 10:53 AM
General Kratos
Jun 10, 2007 02:37 PM
FF2Skip
Oct 11, 2004 08:13 PM
