S/C kit tuned on E85
Old Jan 17, 2013 | 08:14 PM
  #41
soulicious's Avatar
Originally Posted by liquid_helix136
Originally Posted by soulicious' timestamp='1358324121' post='22270164
After that, no more mods.
Thats what they all say...
LOL, maybe not for a while anyways.
Old Jan 18, 2013 | 12:19 PM
  #42
civic_redline's Avatar
Hey Soul, nice numbers. What was your injector duty cycle? Is both pumps and 2000 injectors necessary with this setup on e85? I plan to go this route soon and currently researching the fuel system. Are you running the return fuel kit?
You also stated you have a etune at 10psi, when on that map is changing the pulley necessary?
Old Jan 18, 2013 | 01:49 PM
  #43
soulicious's Avatar
Thanks. On my current tune, IDC is about 49% at WOT. I wanted to go with one pump, but my tuner at the time recommended going dual pumps. FBM also recommended that as well, but that's probably because they wanted some $$$, LOL. Plus, I didn't like the idea of running high fuel pressure, having 100% IDC, or running my fuel pump at the limit. Maybe if I just lived my life 1/4 mile at a time then I would have gone that route. I don't have to worry about have fuel issues and don't have to upgrade later if/when I were to go big turbo and E85. I have an AP2v1, so i have a return fuel system stock.
This fuel chart might be helpful
http://honda-tech.com/showthread.php?t=2924081
When swapping to my 91 octane map, I don't change the pulley. It's just rev limited.
Old Jan 18, 2013 | 08:20 PM
  #44
dsddcd's Avatar
Joey has a few threads here and there, here is one
https://www.s2ki.com/s2000/topic/829...-in-the-press/
For those trying to figure out the impeller speed, remember that Vortech is the same as a Novi.
http://www.vortechsuperchargers.com/...d%20Calculator
As for the belt slip, 3.0" and below is going to be problematic. I would recomend that you step up to the ASP 6.0" crank pulley and adding an idler pulley. Last but not least you try the Geats Fleetrunner belt.
Here is a pics of the ideler I added.
Silvia_Drift
Apr 27, 2015 05:57 AM
rikhemi
South Florida
22
Nov 7, 2010 10:54 AM
egvtec
Oct 4, 2009 02:11 PM
Kyushin
Feb 2, 2008 09:41 PM
danw
Mar 25, 2007 08:22 PM
