Safe boost on S/C
Old Nov 21, 2009 | 05:40 PM
  #31
ILoveMYHonda1984's Avatar
Well, I am probably going to wait until the end of the month to give this a run. We've been having some nice weather here and I don't want to put my car down until I can't drive it any more, once it starts snowing.
I need to check and make sure my fuel pressure is good before and after I go with higher boost. Using the boost a pump it should be fine. I'm don't think there are many people running mid to high 400s on the returnless fuel system yet, on the 06+. I hope it holds up ok
Old Nov 22, 2009 | 04:11 AM
  #32
RAIN H8R's Avatar
Paxton lists the 1220 and 1220sl as macing out at 5300rpm or 17psi. SOS has a different crank pulley you can get to up your boost. That special pulley and a 3.0 blower pulley nets 17, or just a bit more than 17psi on the dot. I wouldnt upgrade to the 1200 blower until you have reached your limit with the 1220.
s2kseven
Oct 13, 2013 09:10 AM
killabee
Oct 4, 2007 07:06 PM
abv
Jun 1, 2007 01:43 PM
GoFaassttt
Mar 22, 2006 10:41 AM
Iceman1
Nov 23, 2005 07:48 AM
