SC Boost Leak: Front compressor cover
Old May 7, 2014 | 10:37 AM
james0933's Avatar
Default SC Boost Leak: Front compressor cover
Ok, so Im performing a boost leak test on an sos kit. I made an adapter to fit onto the air inlet of the supercharger.
The first big leak was a loose t-bolt clamp. The second was from the secondary air valve. After relocating the air pump outlet hose to the intake pipe, i thought i was in the clear.
I didnt get a leak at the valve anymore, but at 5psi or so im getting a big leak behind the supercharger front cover. Ive had it apart before and there is no seal in between the two aluminum pieces. Wth? I doubt its supposed to be like this and its a pain removing everything to access it. Does anyone have any insight or experience with this? I thought i remember seeing seals for sale for the cover at one time.
Old May 7, 2014 | 11:45 AM
RAIN H8R's Avatar
I just had mine off for powdercoating. My n1200 engine oil feed had a large oring behind the compressor cover. It was red in color.
You should have one too!
Sent from my Samsung Galaxy S4
Old May 7, 2014 | 12:41 PM
james0933's Avatar
Yup, youre right! Its definately not there and a shop here confirmed the need for that large o ring.
Was that the same for the novi1000 as well? I dont remember seeing a seal on that one which is why i suspected the 1200 didnt come with one.
Old May 7, 2014 | 02:10 PM
RAIN H8R's Avatar
I will have to dig into pictures on my home pc later today...but i recall seeing one. But that was 4 or 5 years ago already! Sheesh!
Old May 7, 2014 | 04:10 PM
james0933's Avatar
Lol, they still come my way. Ive never had a new one, but the many ive seen in person have never had seal?
Its crazy to think im only now doing a boost leak test after all these years, especially since i was turbo before the s2000 came along.
The o ring did fix it! Im up to 10 psi or so, and then im hearing a faint vibration from the intake manifold. Hmm...
Old May 7, 2014 | 06:45 PM
RAIN H8R's Avatar
You found the oring i take it?
Old May 7, 2014 | 07:15 PM
james0933's Avatar
Yup. Good thing a spare was available to me.
Old May 7, 2014 | 07:45 PM
coolberg's Avatar
Can one of you please post a picture of what you are talking about. I'm trying to find a leak but I'm not very technical. Thanks!
Old May 9, 2014 | 07:28 AM
RAIN H8R's Avatar
Found the picture...now irrelevant... Again this is a Novi 1000
The seal is a LARGE thin o-ring that goes around the out mounting area between the sc unit and compressor cover.
Old May 9, 2014 | 08:58 AM
james0933's Avatar
So no seal on the 1000?
http://www.superchargerrebuild.com/paxton/
Here they call it the front cover o-ring
$20
