SCE ICS Headgasket to lower compression?
Old Feb 23, 2009 | 08:59 PM
  #31
Artisan7471's Avatar
Updates?
Old Feb 24, 2009 | 10:51 AM
  #32
dsddcd's Avatar
None yet but should have some info very soon, the gasket should be here on 2-26
Old Feb 26, 2009 | 06:11 PM
  #33
dsddcd's Avatar
Here is the SCE Titan that came today
Old Mar 10, 2009 | 09:34 AM
  #34
Ian300D's Avatar
Have you installed this yet? Interested on what the outcome is.
Old Mar 10, 2009 | 12:20 PM
  #35
dsddcd's Avatar
Nope, the head will be done later this week and I will install next week but not start up until April most likely
Old Mar 10, 2009 | 01:12 PM
  #36
jwa4378's Avatar
Do / can / will they make an OEM compression version? This is of no help for lowered compression engines... Or those wishing to maintain the stock compression power/boost ratio.
John
Old Mar 10, 2009 | 02:22 PM
  #37
dsddcd's Avatar
John
Yes, they make a huge range of sizes custom tailored to your applications ask for Steve Norr if you call or use the below address. He was more than willing to help me out. I know that there are a few member shops that have SCE as a product line.
steven@scegaskets.com
Old Mar 10, 2009 | 03:11 PM
  #38
jwa4378's Avatar
Can anyone confirm the OEM gasket thickness? I believe its .027", but cannot be sure... I searched and found .027 and .030 as answers from different people.
Thanks! I will email him tonight!
John
Old Mar 10, 2009 | 05:57 PM
  #39
jwa4378's Avatar
Just heard back from Mike Laskey. He has not used them personally, but has heard that they are great at sealing compression, but are not so good at sealing oil/coolant leaks.
He recommended an OEM HG sprayed in Permatex copper for low compression engine applications.
Just FYI for those reading!
dsddcd - Can I get a close-up of the "bead seal" that they run around the coolant passages? Wondering if it looks as effective as OEM...
John
Old Mar 10, 2009 | 06:57 PM
  #40
dsddcd's Avatar
Picture number 3 shows it, you can see the small reciever grove where the ring is inserted
