Science of Speed
Old Nov 5, 2018 | 09:39 AM
kjonesy203's Avatar
Default Science of Speed
So my car hs been finsihed for a little over a month now. Stage 2 sos SC 4” pulley. Made 330 at 8lbs on dyno. Tightened the belt and now am hitting 10lbs on the street. Car has driven perfectly fine and i drive it about 1 time a week. Yesterday i took it out and i noticed a very strange inconsistent high pitch noise. (It sounds like when you rotate rc car wheels backwards if that helps) never made this sound before cant tell if its from the blower or mabey the pulleyes. Anyone every have something similar
Old Nov 5, 2018 | 10:16 AM
s2000Junky's Avatar
try backing off the tension on the sc belt and see if it goes away, you may have over tightened. You don't want to burn up the sc bearings.
Also 2psi is significant. Hopefully it was tuned on 10psi and not 8psi. You want to make sure your ems is correcting the added fuel needed now for a safe afr.
Old Nov 5, 2018 | 10:25 AM
kjonesy203's Avatar
okay i will try that. And yes the car was tuned for 10psi. The tuner had a similar issue on another s2k where he could only hit 8psi on dyno but was hitting 10 on the street. I will loosen the tension and see what happens. Thanks
Old Nov 11, 2018 | 07:18 PM
EOE's Avatar
EOE
If produced in off throttle position, but goes away at full throttle, check your BOV. Mine seized.
Old Nov 12, 2018 | 02:29 AM
kjonesy203's Avatar
Originally Posted by EOE
if produced in off throttle position, but goes away at full throttle, ceck bov. Mine seized
wow I’ll definitely look into that. Thanks
Wydget
Mar 14, 2012 10:15 AM
s2konroids
May 1, 2010 06:45 AM
GoFaassttt
Feb 4, 2005 07:59 AM
mikecl713
Sep 9, 2004 09:22 AM
Silver1
Jul 27, 2004 06:39 PM
