Science of Speed install thread
Originally Posted by integuy98,Oct 30 2009, 05:37 PM
Question regarding the vacuum lines for the install:
No additional vacuum lines are provided for the relocated air control valve and the stock ones don't quite reach once I reinstall the air control box. Does the air control box also need to be relocated or does it go in the same location right behind the front lateral frame member?
Thanks in advance!
Thanks in advance!
How did you guys that installed this kit make it work? Did you go out and buy additional vacuum line? I don't mind doing that, but I'm just wondering since it doesn't say to do so in the install manual.
Originally Posted by Druz,Oct 31 2009, 10:56 AM
I cant remember exactly without looking at my setup but doesnt the kit come with additional vaacum lines?
The 2 included vacuum lines are for the pressure bypass valve and the fuel pressure regulator. Doesn't look like there's an extra one for the air control valve. I found a tee and just hooked up some shorter oem ones to make it work but it's a pretty tight fit. I'll probably fix it later when I get a chance to buy some additional vacuum lines.
Thanks guys.
Thanks guys.
after removing the "hard line", how are the vacuum lines rerouted with the existing two coming out of the intake manifold under the fuel rail and the input/ouput of the air control box and the relocated air control valve?
Secondly, after adjusting the tension on the SC belt, am I supposed to tighten the nut for the tensioner pulley? The install instructions never explicitly says to do so...
Thanks in advance!
By integuy98, shot with Canon PowerShot SD870 IS at 2009-10-30
Thanks in advance!
Cheers,
-- Chris
