ScienceofSpeed Supercharger System Updates
Originally Posted by Chris@SoS,Apr 27 2009, 07:06 PM
-Most notable is the ScienceofSpeed FVM (Fuel VTEC MAP) Controller included in all stage 1 systems for 2000-05.
-and the required MAP sensor voltage control.
-All customers from the initial introductory sale to present have been upgraded to the FVM Controller at no additional charge.
Did this bump up whp numbers in stage one setup?
ps Im real excited about this FVM....mmm lowered vtec and 40 more lbs of tq
Originally Posted by MasterForce,Apr 29 2009, 12:45 AM
HAH!!! i knew it!!! SOS sgt 1 is like KW hi boost!!! well that its!!! Chris it seems your post definately convinced me with the SOS stg one!!! ill be ordering mine in a month or so
Originally Posted by josserman,Apr 29 2009, 07:53 AM
how easily can this be installed? can someone w/ limited mechanical exp install a stage 1 kit? Perhaps install and then bring to a tuner to tune/check over /ect
You'll also need a crank pulley removal tool, you can get a decent one from amazon.com fairly cheap. It's a PITA to get that pulley off, you'll also need a good long breaker bar or metal pipe to get enough leverage to get it off.
You'll need a decent ratchet set, a good torque wrench (possibly two), crank pulley tool, screwdrivers never hurt, breaker bar, and probably some odds and ends. I think the instructions are on SOS's website if you want to look at it.
To make it as simple as possible I'd recommend getting the option that doesn't require you to tap into the engine oil for lubrication.
Originally Posted by CourageOO7,Apr 28 2009, 06:07 PM
AGREED! When the time comes, I would like to be able to switch over to the 1200 instead of having to buy a whole new system.
SOS, I suspect if you sold an adapter plate to convert the old Comptech setups to the 1200 you might clean up because there are a LOT of us out here.
Please consider? If it's possible, how much would you charge for the piece plus the new bushings and trick tensioner.
regards,
-- Chris
Originally Posted by spicyhands,Apr 29 2009, 05:42 AM
So do we have to buy this MAP sensor voltage control or is it supplied?
regards,
-- Chris
Cheers,
-- Chris
Originally Posted by stitos2k,Apr 29 2009, 06:10 AM
From everything I've read it's the easiest to install kit out there. You will probably want an upgraded clutch first.
The oil pan does not need to be tapped. The drain plug is removed and replaced with a fitting.
Cheers,
-- Chris
