SCRAMBLE BOOST BUTTON IN S2K?
Old Jul 11, 2010 | 09:32 PM
AusS2000's Avatar
Originally Posted by dsddcd,Jul 12 2010, 03:16 PM
Not a chance the EMS has boost by speed, boost by throttle position, boost by RPM only, High / Low switch inputs, PI control..........
If somebody has all that working (even just the switch input) can you let me know how.
Old Jul 12, 2010 | 04:06 AM
ap1tuner's Avatar
seriously, i know the aem ems had advertised all these functions but i havent seen anything yet on how to set it up or how to adjust these functions on the fly without sitting down with a laptop. if i hook up the boost to the aem unit, then i still want to be able to adjust the boost pressure from hi to low boosts and scramble at minimum
Old Jul 12, 2010 | 05:42 AM
Spec_Ops2087's Avatar
The Truboost has A, B and Scramble settings only and there is no feedback.
Adjusting boost based on RPM is huge.
With my EBC I have 1 setting for the entire rev range. No matter what I change, there is a take a little / gain a little associated with it.
Old Jul 12, 2010 | 07:03 AM
dsddcd's Avatar
Works great on my car and lots if others. The manual has all the details on setting it up and if anyone needs any help check out my IP build or drop me a PM.
Old Jul 12, 2010 | 07:06 AM
JoeyBalls's Avatar
Originally Posted by m R g S r,Jul 11 2010, 06:28 AM
because with the AEM you can set up traction control, boost by gear/speed etc
yeah, I dont spin in 1st or seconf=d (with 50% tread life I am starting to feel 3rd wanting to get lose in 90F heat, lol), but with Boost by speed I only go to 10lbs in 1st, and 12lbs in 2nd and 3rd gear it is progressive from 12psi to 19psi
Old Jul 12, 2010 | 09:11 AM
ap1tuner's Avatar
ok so which manual can i find the setup instructions in? and still, has anyone wired up the scramble boost? and do you guys always run on the same boost all the time? i remember when i had my profec b in my eclipse i loved having the option of high and low boost. feels safer to beat on when on the road and was eaiser on fuel.
Old Jul 12, 2010 | 10:43 AM
dsddcd's Avatar
It is on the disc that came with the AEM it is the AEMPRO_User_Guide_V2.0.pdf and is automaticlly loaded with AEMPRO.
Here is a breif overview
http://forum.aempower.com/forum/inde...pic,994.0.html
I mounted mine in my console next to the serial guege that is now where the Truboost used to be.
Old Jul 12, 2010 | 05:07 PM
ap1tuner's Avatar
heres my new setup of my gauges. but i still dont know where i wanna put a switch for scramble boost
Old Jul 13, 2010 | 11:34 AM
m R g S r's Avatar
so you're not using the EMS to conrtol boost? lol
Old Jul 13, 2010 | 05:57 PM
ap1tuner's Avatar
as of right now... no. because i dont want to sit on only one boost setting. plus the wastegate is sitting on stock spring pressure bc i havent got it tuned yet. if someone has info on how to setup a way to change from hi/low and scramble boost on the ecu. i actually picked up a small momentary switch that im gonna setup in the car asap for the scramble boost setting. ill post pics when i get it set up how i want it. i gots ideas!
