Should I use AEM C2DI ignition
Old Apr 16, 2007 | 02:29 PM
fperra's Avatar
Default Should I use AEM C2DI ignition
As many of you know, my last engine build used AEM's C2DI ignition box and Honda motorcycle coils. With my new build, I'm considering sticking with the stock coil packs to simplify things. If I go with aem again I need to run some wires while the engine bay is empty. I hope to put the new engine in the car next week. My goal with the new engine is 600 whp on 92 octane pump at no more than 20 psi of boost and water/meth injection. So what do you think? has anyone broken 600 hp on the stock coil packs?
Old Apr 16, 2007 | 03:00 PM
Slows2k's Avatar
The last turbo car I worked on was having prob's with the stock coils at 15 psi. He switched to MSD coils with a set of plug wires.
Old Apr 16, 2007 | 03:58 PM
fperra's Avatar
Thanks Slows. My dyno plots with the AEM ignition had 0 smoothing and the dyno operator was amazed that there was no jitter in the curve. I always wondered if this was because of the ignition.
Old Apr 16, 2007 | 07:39 PM
cpoz's Avatar
I was thinking going the same way (MSD). The system just looks more sound (in theory). I am running the stock set up right now, but after I get more miles on it I am going to up the wick. When the stockers fail, in will go the MSD... I will let you know what i find out if I get there before you
Chris
Old Apr 16, 2007 | 07:43 PM
Slows2k's Avatar
Just an FYI, the MSD DIS-4 ignition box wires in the exact same way as the AEM CDI. When the 1st AEM CDI's came out some had problems, and found out by accident they are configured the same way, plug and all.
Old Apr 17, 2007 | 05:16 AM
Spoolin's Avatar
I asked my tuner about the coils a while back and told him about people switching to the motorcycle coils. And he asked why on earth would you do that when the motorcycle coils don't even put out as much as the stock coils?
He said the stock coils were very good but didn't say what they could handle but I would assume at least 600 whp.
If you remember me Fred, you know who my tuner is and how much he knows.
Old Apr 17, 2007 | 05:28 AM
fperra's Avatar
The key to the motorcycle coils is using them with either the MSD or AEM capacitive discharge ignition modules. The combination puts out a lot more spark than the stock coilpacks. Unfortunately, since the stock coilpacks have the igniter circuit built in, they can't be used. However, if the stock coilpacks are good for 20 psi, then they should be good enough for me since I don't expext to go higher. I've heard a number of people have had ignition problems with the stock ones above 15 psi.
Old Apr 17, 2007 | 12:43 PM
ya@inlinepro's Avatar
We are using stock coil packs on our race car. I don't see how the stock coils would fail.
Old Apr 17, 2007 | 12:58 PM
Spoolin's Avatar
Just my point and what I thought.
merkis1024
Sep 9, 2014 04:00 PM
lotus7racer
May 20, 2010 01:37 PM
s2ksc03
15
Jul 8, 2007 05:28 AM
cjb80
22
Apr 27, 2004 05:29 PM
