Sideways is back on the road again
Old May 12, 2015 | 10:54 AM
Sideways's Avatar
Default Sideways is back on the road again
Stuff happens. Last year I was out for a morning cruise and ended up not driving for 11 months.
The engine stuck wide open for a few seconds before dropping to 3000 rpm. A cursory check found a frayed throttle cable.
I replaced the cable and it still idled fast. I reset the throttle body stop and it idled nicely at 1000 rpm.
Pulled the aftercooler and the throttle body had a big hole in the face. The stainless steel screw came out and was ingested by the engine.
The shaft was broken also. This BDL throttle body has been a pain in the ass for years. I had to return it to BDL a couple years back to fix
poor workmanship.
I ended up purchasing the 74mm Skunk II and enlarging the manifold. I dabbed some JB Weld on the screws for insurance.
Now comes the fun part. I performed a leak down test and it was 50% abnormal to cylinder #4. Oops, bent valve.
Since it was to be down I decided to change the supercharger drive pulley setup.
I called Lee at ASP and had a new set of pulleys built. Eight ribs and larger with the crank pulley being enlarged from 6 inches to 7.5 inches.
The supercharger pulley was 4 inches. Same ratio, 6 to 3.2 is the same as 7.5 to 4.
I had a head built with porting, oversized valves, Inconel exhaust valves, ti retainers and all the bells and whistles.
Pulled the old head and the #4 piston and wall were showing signs of the stainless steel screw sticking around for a few seconds.
Sent the bottom end off to Mike Laskey at Laskey Racing to work his magic.
Attached Thumbnails Sideways is back on the road again-img_0837.jpg   Sideways is back on the road again-img_0559.jpg   Sideways is back on the road again-img_0566.jpg   Sideways is back on the road again-img_0568.jpg
Old May 12, 2015 | 11:00 AM
Sideways's Avatar
I decided to up the compression a tad and went with CP 10:1 pistons. Took the bottom end and head to Tony Fuchs
to assemble.
As of this morning it is running strong. After break in I will post up some performance numbers.
Attached Thumbnails Sideways is back on the road again-img_0579.jpg   Sideways is back on the road again-img_0816.jpg
Old May 12, 2015 | 11:03 AM
Sideways's Avatar
Some drive pictures:
Attached Thumbnails Sideways is back on the road again-img_0617.jpg   Sideways is back on the road again-img_0619.jpg
Old May 12, 2015 | 11:23 AM
baZurk's Avatar
Looks good! Must feel nice to have it running again!
Old May 12, 2015 | 01:23 PM
V6 Donut's Avatar
I was thinking the same!
Old May 12, 2015 | 01:28 PM
Spoolin's Avatar
Glad to see the S2K veteran getting the S back on the road. Not many of us true veterans around from the beginning it doesn't seem anymore or maybe there are more in the NA section I haven't kept up with.
Old May 12, 2015 | 03:05 PM
bruthaboost's Avatar
I was wondering how you got your crank pulley to fit with your water pump pulley. I increased the diameter of mine to 7" and had to have slightly smaller diameter water pump pulley made.
Old May 12, 2015 | 03:55 PM
s2kcrick's Avatar
Nice! I seen your car there at Tony's for a while. I'm having Tony do work on mine as well. Gonna get a full on valve job done on the head probably in the next few weeks. Is there a big benefit (power to money ratio) to porting the head or is it just to squeeze a little bit more out of it?
Old May 13, 2015 | 01:17 PM
siadam's Avatar
That's b/c everyone else wised up and quit dumping $$ into this hobby, but the tried and true of us are still here.
Old May 13, 2015 | 02:02 PM
squirrels2k's Avatar
Good to see your up and running again.
