Sideways is back on the road again
Originally Posted by Sideways' timestamp='1431457210' post='23610336
I decided to up the compression a tad and went with CP 10:1 pistons. Took the bottom end and head to Tony Fuchsto assemble. As of this morning it is running strong. After break in I will post up some performance numbers.
Thank You Brutus.
I spent many hours working that manifold. Took 4 lbs off of it along with all smog and plumming.
It is a breeze to install now because you can reach between the runners and apply the nuts.
I totally polished it and had it finished with a cold ceramic coating.
Originally Posted by Brutus' timestamp='1431554958' post='23611990
[quote name='Sideways' timestamp='1431457210' post='23610336']I decided to up the compression a tad and went with CP 10:1 pistons. Took the bottom end and head to Tony Fuchsto assemble. As of this morning it is running strong. After break in I will post up some performance numbers.
Thank You Brutus.
[/quote]
Questions!
How did you know where to cut without making the walls too thin or create a hole?
Once most of the material was gone, how did it come out so smooth like sculpture?
The cold ceramic coating is very intriguing. did it help lower ait? is there a trade name for it?
Originally Posted by Spoolin' timestamp='1431466110' post='23610558
Glad to see the S2K veteran getting the S back on the road. Not many of us true veterans around from the beginning it doesn't seem anymore or maybe there are more in the NA section I haven't kept up with.
