Sidewinder turbo and intake pipes
Old May 4, 2014 | 10:32 AM
s2konroids's Avatar
Default Sidewinder turbo and intake pipes
I have mase turbo kit with a GT35R, its a sidewinder so sits above the cross-member and in front of the block. I was thinking about relocating the air filter to the faux vents or further away, however this would introduce bends in the piping and wondering if its actually beneficial and if the bends will cause any power drop or any other negative effect?
Thanks
Old May 4, 2014 | 07:22 PM
s2k manic's Avatar
doesn't the mase kit have the filter on the left side of the engine bay? If so a large diameter pipe will be needed to keep from having a restriction. I would think as long as you don't add more than a 90 degree bend you should be ok. in for results
Old May 5, 2014 | 08:38 AM
s2konroids's Avatar
No mate it sits right in front of the block.
Old May 5, 2014 | 09:02 AM
baZurk's Avatar
You could try to use ducting from the front bumper to bring the cold air into the engine bay towards the filter. From there you could go as far as making an induction box to house the filter to separate it from ambient temps of the engine bay.
MARK AUS S2K
Oct 17, 2017 06:06 PM
manny-s2000
Nov 17, 2016 08:54 PM
turbodreamz22
Apr 25, 2014 05:43 AM
ChefJ
Jun 27, 2007 05:48 AM
