Smaller pulley on comptech FRP?
Old May 17, 2009 | 04:18 PM
jdmdohcpower's Avatar
Default Smaller pulley on comptech FRP?
CT has told me that I can go up to 8psi on the FRP that came with the kit. Talking with SOS and they say I must do a AEM FIC? Done a lot of searching and cant find a solid answer about tuning. Is it a must for the upgrade or is a 7psi the max on the FPR's range?
Old May 17, 2009 | 07:27 PM
s2k aok's Avatar
with the rr fpr i was under the impression that the consensus was the ap2 7 psi pulley for the ap1. anything greater than that and you'd need a standalone and injectors.
Old May 17, 2009 | 09:09 PM
S2SEXY's Avatar
it depends on your exhaust setup too.
Old May 18, 2009 | 07:11 AM
Well with my front mount, IM getting under 3psi on stock pulley. I think the FRP can go to 7psi, so if I get the 9psi pulley I may still be at 7-7.5psi of boost - safe for the FPR.
Does this make any sense or am I crazy and just go with the 8psi pulley and tune the FPR and be happy.
Old May 18, 2009 | 09:47 AM
ScienceofSpeed's Avatar
Former Sponsor
I didn't understand you when you called on Friday. Are you saying that you're getting a 3 psi drop over the core? The engine cares about the pressure in the manifold. So, you could use a smaller pulley to bring up the manifold pressure (we have these on sale now if you're interested).
However, if you're seeing a 3 psi drop through the inter/aftercooler, I'd probably want to look at changing that setup.
regards,
--Chris
Old May 18, 2009 | 12:28 PM
Its about a 2- 2.2 psi loss. It is a big front mount so they told me to expect 1.5
Just ordered a 3.8in
lvd1102
May 13, 2010 03:20 AM
TheBigShow
Sep 2, 2009 08:11 AM
revhi
May 31, 2008 06:25 PM
ego
Dec 11, 2007 02:52 PM
kylemonster85
Jun 11, 2007 10:26 AM
