smoke from return line
Old Aug 6, 2009 | 08:05 PM
combats2000's Avatar
Default smoke from return line
sup guys i will take mroe pics tommrow, but the tuner today told me that my oil return line that goes into the pan is causing the oil to come back thru the turbo and cause the smoke, he was 100 % sure.. here is the oil pan pics of where it was tapped
these are the only pics i have at the moment
he was telling me that the line wasnt angled down completly so it was backing up... any ideas on what i can do differently?
Old Aug 6, 2009 | 08:43 PM
TRBOKEV's Avatar
That's where inline says to put it....
Old Aug 6, 2009 | 09:06 PM
i think it may be the lines.. not angled properly
Old Aug 6, 2009 | 09:48 PM
justnnavy's Avatar
it does look pretty long man
Old Aug 6, 2009 | 10:02 PM
wat do u mean pretty long?
Old Aug 7, 2009 | 10:03 AM
blueap2's Avatar
Is your turbo's cartridge a perfect 90 degrees? Meaning is the turbo drain vertical?
Old Aug 7, 2009 | 10:35 AM
AndyFloyd's Avatar
I had mine tapped as high as possible. Make sure your drain line goes directly downward off your turbo.
Old Aug 7, 2009 | 10:43 AM
Best pics I can take, its not directly down, more like angled down, then straight then a slight up,, take a look
Old Aug 7, 2009 | 10:51 AM
MADjdm's Avatar
You do not want any portion of the line to channel up.
Oil is drained by gravity
Old Aug 7, 2009 | 11:11 AM
can you see this being the case here?
