somethings wrong with fuel system, pump/injectors?
Old Oct 7, 2009 | 09:39 AM
spectacle's Avatar
Definitely sounds like loose ground somewhere. Or maybe a halfgone fuse
Old Oct 7, 2009 | 09:50 AM
camuman's Avatar
disconnect the fuse for the stereo power wire, that way amp/and power wire stop getting juice. then start checking all the engine grounds. then check behind the radio. maybe something is shorting out.
i am with others, electrical issue, possible ground problem, or short somewhere.
Old Oct 7, 2009 | 02:04 PM
lewiS2K's Avatar
well it's confirmed..... my knock sensor is completely severed ... i can see the wire dangling... it is on order
as for the electrical, I will do as you guys say.. first i will check all the fuses.. then I will check to see if there are any wires that could have possibly shorted out...
thanks for the suggestions guys...
Pokemon
Sep 13, 2013 06:54 AM
RedCelica
Dec 2, 2010 05:45 AM
dsddcd
Dec 31, 2008 11:50 AM
woo
Oct 8, 2007 07:36 PM
hboy7777
Apr 26, 2004 05:30 PM
