SOS/COMPTECH/VORTECH owners...
Old Jun 8, 2010 | 07:23 PM
RAIN H8R's Avatar
Default SOS/COMPTECH/VORTECH owners...
I am thinking of installing an AEM Oil temp sensor to run with my AEM EMS. The problem is that I have the COMPTECH SC (N1000) and the oil return from the blower goes where the oil drain is on the oil pan.
So, where are you guys mounting the temperature sensor? If your drilling holes in the pan, how low are you drilling the hole? Please post pictures if you have one.
Old Jun 9, 2010 | 05:56 AM
CourageOO7's Avatar
I just have a sandwich plate and have the sensor threaded in one of the 1/8th inch NPT holes.
I know it's not as accurate as having it threaded directly in the block but it was convenient.
Old Jun 9, 2010 | 06:51 AM
goldenfri's Avatar
Thats how mine is mounted as well. Greddy makes one.
Old Jun 9, 2010 | 07:05 AM
Spec_Ops2087's Avatar
I wouldn't put it in the oil pan, stick it where the oil pressure warning light is mounted.
Old Jun 9, 2010 | 07:44 AM
CourageOO7's Avatar
Glowshift makes mine.
Old Jun 9, 2010 | 07:11 PM
RAIN H8R's Avatar
Hmm, so the sandwich plate for the oil filter is where you guys are mounting your oil pressure and oil temperature gauges?
Isnt the oil filter housing the first place after the oil pump that the oil travels to? And then to the factory oil pressure sensor?
Any issues with the glowshift adapter? How about the Greddy? I think I'm going to buy one right now. How is the clearance with both sensors installed when removing the oil filter?
Is there a way to use an AEM coolant temp sensor for oil pressure? It is not a 1/8 npt, at least I don't think it is.
Old Jun 10, 2010 | 06:12 AM
LeonGalt's Avatar
If you do buy one of these, do you mind posting up some pics and impressions afterwards? Maybe even where you got it from?
I currently have 1 oil temp sensor in place (in a weird location) and have capacity for 1 more that I haven't figured out where to stick yet.
Thanks,
J
Old Jun 10, 2010 | 05:55 PM
goldenfri's Avatar
I had the greddy, then switched to a glowshift when I installed my oil cooler. Greddy was hard to get it not to leak, but my glowshift doesn't leak when I get it tight.
s2konroids
Aug 28, 2018 08:25 PM
nibble
Nov 9, 2007 06:17 AM
AllStock27
May 4, 2006 08:37 AM
MB
Dec 2, 2005 05:32 AM
jdmdohcpower
Oct 31, 2004 04:45 PM
