SOS fuel pump wire kit help
Old Sep 2, 2014 | 05:12 PM
lude92_si's Avatar
Default SOS fuel pump wire kit help
Hey guys trying to install my walbro 450 with SOS wire kit. I can't seem to get the pins on my power and ground to fit in the OEM plug. I even tried one without the wire ans still will not go any tips? Seems the 12gauge wire is pretty thick for the pins provided. After over an hour fighting with it I'm calling it a night. Almost seems the pins I got are to big to fit the OEM plug.
I'm open to advice!
Thanks
Old Sep 3, 2014 | 03:17 AM
lude92_si's Avatar
Thought of some options lastnight.
A. could drill out factory plug to fit the pins then use a silicon or leftover Honda bond to seal the back so it wont push out...
B. Remove the plug altogether and just shrink wrap the pins and plug them in. This seems like a better idea.
Unless I'm doing something wrong shoving 12g wire into OEM pins and trying to her them yo fit right just isn't going to happen :/
Old Sep 4, 2014 | 07:35 AM
starrman's Avatar
I would call SOS... from my understanding that kit is supposed to fit the OE connections...they even say the sourced the stuff from Japan.
Old Sep 4, 2014 | 12:53 PM
ScienceofSpeed's Avatar
Former Sponsor
The kit includes factory terminals. You must use a proper crimper as detailed in the instructions. They are available for very inexpensive on sites like Amazon (recommendations in the instructions). If you do not use these, the terminal will not crimp properly and it will be impossible to fit in to the connector.
Old Sep 5, 2014 | 01:56 AM
lude92_si's Avatar
I got the proper crimps and it is a must. I ruined a few,pins trying to get the bigger 12g wire to fit. So I'm waiting on more then give it another shot. Thanks
Old Sep 5, 2014 | 02:42 AM
Redline S2K's Avatar
Here is the link I mentioned in the PM
https://www.s2ki.com/s2000/topic/108...os-wiring-kit/
MorngWoodStewie
Oct 17, 2016 08:02 AM
lude9285
May 10, 2016 10:53 AM
schhim
Nov 19, 2015 11:58 AM
s2k_bmich510
Mar 14, 2009 12:15 AM
Ibn_Danil
Mar 14, 2008 05:39 PM
