SOS SC Kit
Old Dec 13, 2010 | 08:39 AM
ZeroF's Avatar
Default SOS SC Kit
Hello FI Guys
I have a SOS Stage 2 kit on my car currently, I am debating changing over to a FMIC and ditching my aftercooler.
The water pump for the aftercooler is shot, its making tons of noise. One of my friends mentioned to check for a air bubbles, no dice on that
Any one have an idea of where to get a replacement pump besides SOS? I am assuming this is a universal fish tank pump or something similar. I have yet to have the chance to remove the bumper and take a look at it.
I understand I will loose 1 to 2 PSI going to this over my after cooler but from what I have been reading its possible to have some gains in the long run when you start talking about heat soak. I can always change the pulley to get the desired boost levels. I am not going for world records here I am fine with 8 to 10 pounds of boost.
Also anyone know of a company that makes a FMIC setup for the SOS kit? I am assuming I can order a bracket to mount the blower from comptech of possibly vortech to adapt over to work with this kit.
http://www.ultimate-racing.com/Products2/S...VortechSC.shtml
I appreciate everyone's ideas of input on the matter.
Thanks
Nik
Old Dec 13, 2010 | 09:52 AM
s2000Junky's Avatar
I would just replace the pump. You can get a universal one from Bosch for like $100.
Most Fmic will lose 3-4psi. Which means you have to max out our blower speed just to get some boost. Its not an efficient system for the SC. And your blower will wear out quicker. Spend the money on an upgraded heat exchanger and pump through SOS if you don’t already have it. Money better spent.
Old Dec 13, 2010 | 10:26 AM
JawKnee's Avatar
I believe the pump supplied with the kit is a Johnson unit, at least the Base kit -- not sure if the water pump differs for Stage 2 or not.
I think it's a CM30?
http://www.johnson-pump.com/JPMarine/produ...tion/index.html
Old Dec 13, 2010 | 11:44 AM
s2000Junky's Avatar
A larger pump is used/recommended in combination with the larger optional heat exchanger. I'm not sure if the larger heat exchanger is part of the stage 2 package, I don't think it is.
Old Dec 13, 2010 | 01:17 PM
ZeroF's Avatar
I have the larger heat exchanger, I know they use a larger pump with the stage 2 kit as well.
Thanks for the input guys!
Old Dec 13, 2010 | 01:20 PM
Kyushin's Avatar
Banned
Mine is really noisy too, I set up my aftercooler and heat exchanger myself and its working great. Lemme know if you want me to take a look for you when we have a chance.
Ill try and find you that like but yes those pumps can be had for well under 100
Old Dec 13, 2010 | 01:25 PM
Kyushin's Avatar
Banned
http://compare.ebay.com/like/250735652524?...4=263602_304662
http://www.johnson-pump.com/JPMarine/produ...ation/cmco.html
I have the upgraded SoS water pump and I believe it is (22.5L) ~6.5GPM being its the CM10 22mm I believe, you can get a larget one, of course, for a better flow rate for nearly same price a retail SoS pump costs.
The eBay link is for the CM 30 which rated for 8 GPM.
http://www.johnson-pump.com/JPMarine/produ...ion%20curve.swf
Old Dec 13, 2010 | 01:33 PM
raymo19's Avatar
Originally Posted by JawKnee,Dec 13 2010, 02:26 PM
I believe the pump supplied with the kit is a Johnson unit...
Sorry but this made me
Maybe a "Big Johnson" unit would solve your problems.
Sorry again - may be a Southern thing.
Old Dec 13, 2010 | 01:53 PM
dsddcd's Avatar
Originally Posted by TEHSTIG,Dec 13 2010, 12:39 PM
Hello FI Guys
Thanks
Nik
First off if you do go with a FMIC like others had alluded you will see a reduction in boost to the tune of 2-3PSI. If you would like to make this up you are going to need a new pulley.
If you do not mind this then a FMIC is not a bad choice. Personally I prefer a Air to water setup for the street and FMIC for the track. If you do some research you can get some more details and come to a decision that best suites your wants and needs.
The UR kit will bolt up to the SOS just like a Comptech. Just drop them an email and I am sure they will be happy to help you.
Old Dec 13, 2010 | 02:34 PM
manny-s2000's Avatar
If I ordered the tuner kit + upgraded heat exchanger does that mean I get the bigger pump? What's the model number of the bigger one.. I will check mine when I receive it so I don't have to take the bumper off again if it shits itself.
Moddiction
Oct 24, 2014 02:58 AM
MBHs2k
Aug 20, 2013 06:02 PM
Q8Boy
Jan 11, 2008 03:33 PM
wingnutLP
Apr 12, 2007 01:04 PM
