SOS stage 2, only making 110whp gain. HELP!
Old Sep 18, 2013 | 01:23 PM
  #21
soulicious's Avatar
I don't think that your exhaust is the issue. I run the stock exhaust and test pipe for my 492whp DynoJet SOS kit w/1200 blower.
Old Sep 18, 2013 | 01:25 PM
  #22
soulicious's Avatar
Also, I ran stock exhaust when I was running 10psi. Gains were 160whp over my stock baseline.
Old Sep 18, 2013 | 03:22 PM
  #23
McFlurry's Avatar
Originally Posted by Jmays2k
Yea you can just get there header and exhaust but I think the testpipe is built in. and I think it could be close with a proper tune. if you are doing a new pulley get there 3 inch do that with some race fuel you could see close to 500whp maybe.
SOS website says not to go lower than 3.2" pulley on AP1s?
Thanks. Ill try having the 3" exhaust system. Do headers have optimum diameter size also? Again, sorry for the noob question.
I dont think we have Race gas here in the Philippines. Some even told me that pump gas here is notches lower than the pump gas there. Something like a 95oct gas here, if exported there, would only be comparable to your country's 91oct gas. Doesnt make much sense to me. Any thoughts?
Originally Posted by s2000Junky
You should be seeing 11-12psi with that 4" pulley on that 1200 blower. You sure its the 1200 and not 1220? At any rate, the first thing I ask when this situation comes up is boost verification, was the belt slipping. The belts are not easy to gauge proper tension, and even if not slipping on first initial install, they almost always do shortly after and need at least one follow up tightening after they stretch/break in.
THAT's WHAT I'M TALKING ABOUT! according to SOS, the 4.0" pulley should be making something around that psi range! Yes it is definitely the 1200. Ill post photos of the setup and tables tomorrow. Please fill in your ideas. I have no idea how to know if the belt is indeed slipping.
Originally Posted by 1SlowSi
Originally Posted by yamahaSHO' timestamp='1379521324' post='22784748
Don't get hung up on numbers.
There comes a point where you need to be concerned with numbers I.E. the situation he is in right now trying to figure out why. Thats like me throwing 30 psi of boost at motor, making 400whp and saying not to be concerned with the numbers.
I am in precisely that kind of frustrating situation :|
Originally Posted by APoner
We need more info to be able to help you like others have said
Boost verification. (what was your max psi @ the manifold)
post the Ignition tables.
Also what were your afr at?
Will post tomorrow. Thanks man.
Originally Posted by d16tof22
Check the boost first. On a stock exhaust and cat i did 330whp with the 4.2" pulley (9psi) on a dyno dynamics that supposedly reads very low. The belts can easily slip if not tensioned properly or if theyre worn out.
Yeah, based on what I have been researching for a couple of months before buying the SOS, I was expecting to get to approx 350whp considering i have a simple exhaust system and considering that i have a JDM version (250bhp). Feeling so bad...
Yeah I know boss.... I posted a link of a 9.5/10psi setup above and was amazed how his numbers turned out. The link happened to be soulicious' setup.. it was actually yours!! Nicely done boss!
I was really looking forward to numbers like that when I bought my current setup. Ill post data tomorrow. I hope you guys can share info that could make my numbers be at least something close to your setup's output.
Old Sep 18, 2013 | 04:44 PM
  #24
eseDOSke's Avatar
Check your belt tension since its a new install, the belt will stretch a little after break in. Your belt might be slipping.
Is your clutch in good condition? Numbers can be skewed if your clutch is slippin.
Being that you're in PI, are there any other good "reputable" tuners around? Might be scarce...
Old Sep 18, 2013 | 04:55 PM
  #25
McFlurry's Avatar
Is your clutch in good condition? Numbers can be skewed of your clutch is slippin.
Yeah Ill check the tables in a while and post them here for you gurus to see if the belt is indeed slipping. How do I fix the issue if the belt is slipping? Just tighten?
There are a number of "reputable" tuner names here. However, since S2000s are somewhat "uncommon to rare" here, I dont know if anyone really competent enough to say that they have in-depth experience with tuning s2ks. More so with SOS SCs
I am considering the fact that the temperature,atmospheric pressure, and octane ratings here are making the numbers drop. I just didnt know it would be this drastic. Sigh...
Old Sep 18, 2013 | 06:40 PM
  #26
yamahaSHO's Avatar
If you want to be concerned with numbers, it should be the numbers the ECU is showing (calibration/logs). If you're that far off your target, you should already know there is something going on without a dyno.
As stated, Vortech's slip, especially if it is new and you just installed it. The only way I could stop it with my SHO on a 3.2" pulley, was to get a Reichard Racing Pulley and a heavy duty belt that was tightened to hell. My upper main bearing did not live a happy life.
Old Sep 18, 2013 | 07:27 PM
  #27
ScienceofSpeed's Avatar
Former Sponsor
Sorry to hear you're having problems, but this should be easy to diagnose.
1. Post your manifold pressure graph, preferably from the dyno, making sure the that the dyno pressure sensor is calibrated. At peak, we'd expect around 10-11 PSIg at sea level at 9000 RPM. If the pressure is off, you either have a leak or belt slip.
2. If pressure is good, verify engine compression.
3. If manifold pressure and compression is good, either fuel ratio or ignition is off.
Is your fuel rating based on US standards - (R+M)/2 or Euro/Asia standard RON? I would expect this to be RON. If RON, this is a very aggressive pulley for that fuel - which in the US would be around 90-91 octane. If so, this may explain why your tuner is very conservative with ignition timing.
Old Sep 18, 2013 | 07:45 PM
  #28
McFlurry's Avatar
How do I know if manifold pressure and compression is good? And how do i know if fuel ratio or ignition is off? Sorry for being such a noob on this.
Old Sep 18, 2013 | 07:53 PM
  #29
yamahaSHO's Avatar
Log the AEM for your manifold pressure or even check boost pressure and vacuum with a boost/vac gauge if you suspect the MAP sensor is not calibrated properly. Compression will have to be tested with a compression tester which will require moving the plugs. Fuel will need to be checked with WBO2 sensor. Timing can be logged if your map is locked.
If you suspect a boost/vacuum leak, you can then pressure test the charge piping/aftercooler/intake tract. I made my own cap with an air compressor fitting and regulated pressure through my air compressor.
Old Sep 18, 2013 | 08:33 PM
  #30
McFlurry's Avatar
What compression is supposedly "good"? I mean is there like a magic number that I should look out for when having a compression test?
