SOS vs Kraftwerks
Originally Posted by soulicious,Nov 15 2009, 08:05 PM
How many known KW owners overspun their rotrex? I know someone local in my area (hasn't published anything yet...don't ask) who overspun and required a new engine.
Originally Posted by JustinC,Nov 15 2009, 01:45 PM
Well you are looking at PSI spec'd from the manufacturer and you don't know what volume the container was that they measured it in. Everyone is correct in that if you change the pulley sizes it makes no difference on lowering the RPMS. Meaning if you have a certain size crank pulley and blower pulley, making the blower pulley smaller or making the crank pulley larger both will increase the blower rpms. So if the blower is maxed out at the 3.0 inch blower pulley then its maxed out. You can't get anymore PSI out of it without over spinning it. Now if the 3 inch is the smallest pulley and they offer a different crank pulley, then the blower is not maxed out at the 3 inch pulley in terms of blower speed.
The only reason I see needing to change the crank pulley is if your blower speed can be increased beyond what a small pulley can do alone on the blower. If your blower can handle say 20psi but you can only drive it up to 15psi from a blower pulley, then you have to change the crank pulley size to net the other 5psi. has nothing to do with getting max psi without over spinning, the two don't relate in this matter, someone just confused the two somewhere down the communication path like several other rumors floating around on these forums. This is how I see it.
It would merely be a coincidence. An over spun blower creates blower damage, not engine damage.
Originally Posted by s2000Junky,Nov 15 2009, 08:27 PM
This is what I was thinking as well from my other post. Its like on my motorcycle for example. I have a sprocket on the rear wheel and one on the primary/motor. Both are connected to a single chain. If I want to change the rpm speed vs mph I change the sprocket size, I have my choice of two sprockets, it doesn't matter which sprocket i change, they both net the same result of the rpm vs mph. The only difference is changing 1 tooth on the primary/engine side is worth 3 teeth to get same results from the rear wheel. So when I think of the blower being the rear wheel and the crank being the primary/engine side there is no difference.
Whew...I think our work here is done.
There has been one guy with a stock KW high boost that blew his charger but KW replaced asap!
I spoke with OJR a week ago about the updated pulleys... he told me too look out for a post on s2ki in the next few weeks.
s.hasan546,S2kHabitat, s2000Junky: Sorry, I didn't mean to strike a nerve. I should be more careful of how things are worded here. I meant bits of pieces of the damaged blower (from overspinning...at the track) got into the engine. You can say it is BS, but believe whatever you want.
For whoever asked, the Rotrex is a precision engineered bucket of gears. If you break one, the whole thing will probably shatter and potentially send millions of pieces of metal particles shooting into your intake. Therefore engine damage is not out of the question.
But let's not blow things out of proportion. This would happen on any s/c, turbo, or whatever spinning gizmo.
