SPAL Fans on OEM Radiator w/ SOS Kit
A relay is not required for anything lower than the "high" or "extreme power" Spal fans. The low and medium profile fans will be fine on stock wiring. You want a puller fan for your application.
Regarding mounting, there's another solution; these zip-tie-like mounts that go through the front of your radiator between the fins and then zip down on the back. Very cheap but handy solution, I know for a fact LHT was using them before they started selling their radiators with welded-on shrouds with mounting points for the Spal fans.
This is what they look like:
https://www.summitracing.com/parts/d...SABEgLW6_D_BwE
i personally think that the zip tie method to mount aftermarket fans is really ghetto and bad. You have to bend the fins of the radiator and with time it will puncture the core and it will leak. I'm no fabricator but its super easy to make proper fan mounts.
you just buy these spal fan mounts and bend them to the oem mount spounts and bolt them up, Its very very easy
https://www.ebay.com/sch/i.html?_fro...mount&_sacat=0
Thanks for your feedback.
Just so I'm clear, are you saying I don't need to run a relay with the SPAL medium or Low Profile fans?
Also, if I change just the fan on the right side (passenger side), which SPAL fan do I get? The puller or pusher fan? That's with me keeping the OEM fan on the left side as you recommended.
For what it's worth, I'm selling my LHT performance large radiator with SPAL fans and shroud for $300 picked up. Worked great with my SOS SC kit with zero clearance issues. PM me I can send pics if you like
Somewhat bringing back from the dead and wanted to add a result...
I had this exact problem since my aftermarket radiator core leaked out and I found an 06 OEM radiator locally with about 90k miles to replace it, totally clean. My LHT SOS air-to-air build had a tube that the OEM fan would not clear. So I transferred my Spal fans to the OEM radiator and used those ties. I also felt uncomfortable with this solution since it's tying to a much thinner core, but I figured it was temporary just to get it home.
As you can see in the pics, it clears everything neatly. The Spals are much lighter than OEM and are plug-n-play, I believe LHT wired it that way. I drove it 20 miles and even gave it a spirited run against a modified Genesis... Everything was solid
I also wanted to add that the aftermarket core leak was NOT caused by the tie. You can see in the radiator pic with the back of the ties, the lower right hand corner of the radiator is discolored in green from the leak. The leak wasn't coming anywhere from the tie. The fans were completely dry when the radiator gave out.
Both are 12", VA10-AP50/C-25A
And here's the hole on the core, you can see the opening is outward so the core had failed in the corner here.
