Stock Compression Tune 93 & Pump as well as Q16
Old Apr 5, 2011 | 06:04 AM
Irishflame27's Avatar
very nice Joey, keep it together now!
Old Apr 5, 2011 | 06:38 AM
DFWs2k's Avatar
Originally Posted by jaundice
So, at 23 psi and a 3mm head gasket, you made 578/415 and stock compression at 16 psi you made 543/390? You are the only one getting those kinds of numbers out of that PFab kit. I personally think 543 at 16 psi is kinda high, but it is on stock compression and I wasn't there. Is this rear wheel horsepower and on what kind of dyno? I could never even come close to your numbers with a fully built 9:1 motor and much less restrictive exhaust than you have. I know you have a 2.2L motor, but damn. Does meth really add that much? Were these numbers with meth spraying? Do you have any runs without meth?
it was evans' dynapack*, so most likely higher than the dyno we used
Old Apr 5, 2011 | 06:40 AM
JoeyBalls's Avatar
Dynapack, not DynoDynamics ^
Good bad or indifferent
http://www.youtube.com/watch?v=UZXbk3o-xHg
I always thought it was
DynoDynamics, Dynapack,DynoJet,Mustang as far as Low to higher reading, either way like you said, it's just a tool not a wiener measuring device
Old Apr 5, 2011 | 06:45 AM
DFWs2k's Avatar
fixed, yea, dynojet
dynos are just tuning tools, so can't compare across different dynos
Old Apr 5, 2011 | 08:21 AM
jaundice's Avatar
I wasn't measuring wieners. Just always impressed with your numbers. I chased you for a year before I put mine in a telephone pole. Just could never come close with nearly identical setup (minus meth), but different tuners and dyno's. Just asking questions. It is a forum after all...
Old Apr 5, 2011 | 08:34 AM
JoeyBalls's Avatar
I was just busting your balls, I think the .2 liter difference really does make a huge difference
Old Apr 5, 2011 | 08:55 AM
jaundice's Avatar
LOL. We will see. I am building a 2.4 stroker right now. I hope the .4 makes a humongous difference
PndaS2K
Oct 15, 2012 09:06 AM
RichV
Oct 28, 2009 07:59 PM
stantaur
Mar 19, 2008 08:18 PM
bc02
May 26, 2007 10:45 AM
f20kills
Apr 21, 2006 09:10 PM
