Stock fuel rail max pkwer?
If you have an ap2 (07) what fuel rail will work? I think full blown has one but it's over $200.
Is there a way I can make my ap2 ID1000's fit a ap1 fuel rail..... I need to make it a return system
Also what fitting (bulkhead) was used to connect the return line to the hanger?
Thanks.
I have seen your set up and am trying to understand it, so your fuel line goes through the fpr to the rail (Where did u get the adapter to connect to the rail)? Then your return line returns right off the fpr back to the tank.... you can still use a flex fuel sensor in the return line correct?
Thanks.
Thanks.
08s2000CRbackinblack
Nov 17, 2013 10:41 AM
