Supercharger ?
Old Feb 28, 2014 | 07:46 AM
PickelJuice's Avatar
Default Supercharger ?
Im ready to buy a complete Supercharger Kit.. ive done research but still want direct opinions to todays day. I do not daily drive my s2000 nor track it. Im looking into buying a simple kit that i can get over 400hp preferably 450whp with. Every opinion is appreciated and if you have links to your suggestions that would be great!
Thanks please dont yell at me
Old Feb 28, 2014 | 08:09 AM
Jorden's Avatar
i don't know much about the different supercharger options out there but i heard HKS can get around 400Whp by changing the pully out
Old Feb 28, 2014 | 08:10 AM
MdPirate's Avatar
There have been several conversations on this subject.
400hp Supercharged
Unfortunately there is nothing "simple" about forced induction, especially the numbers you are talking about. I would take a look at some build threads and see what supporting mods were used to achieve that hp range. You'll see it is not as simple as slapping on a kit.
Old Feb 28, 2014 | 09:52 AM
Reckon's Avatar
Read through the FI subforum:
https://www.s2ki.com/s2000/forum/142...ced-induction/
Once done, you should have your answer.
Old Feb 28, 2014 | 11:50 AM
Bliss's Avatar
Hope you have some cash.
Old Feb 28, 2014 | 01:29 PM
alexis_s2's Avatar
Go to TTS ROTREX
Old Feb 28, 2014 | 02:21 PM
99SH's Avatar
Since this is a weekend driver and not track duty, it doesn't warrant a 450whp car - but that's just my opinion.
Also peak HP doesn't really matter on the street (unless you drive around town cruising at 7-8K RPM). What matters is midrange torque which will be in the RPM power-band you'll use most. Get a Novi 1200 setup, such as the SOS kit. It's ultra reliable and streetable. Swap pulleys for a smaller one and you'll have a nice mid-range torque profile.
Old Mar 1, 2014 | 12:21 AM
\\s2kris//'s Avatar
450 with a supercharger is no easy task or cheap. Im running a comptech NOVI 1000 kit with a FMI and almost 10lb of boost and I'm hitting around 350hp.
Old Mar 1, 2014 | 07:10 AM
lude92_si's Avatar
My set up was simple and hit 405whp around 15psi, novi1000. AEM ems, id725,walbro 255,3"pulley,sperco large heat exchanger. 93 pump 3bar map. Car ran better than stock!
Injectors and pump will forsale soon
Old Mar 2, 2014 | 07:56 PM
Moddiction's Avatar
Former Sponsor
400 is easy. Just need fuel, engine management and vortech, SOS or kraftwerks. Comptech is able as well as shown above but at its limits.
My vortech kit made 406 at 12.5 psi.
