Supercharger Problem
Old Mar 30, 2010 | 10:27 AM
s2000Junky's Avatar
Oh ok, I misread.
Do you have any local club members that are experienced with this kit that you can go to?
Old Mar 30, 2010 | 10:37 AM
TheBigShow's Avatar
not that i know of. i've posted in the mid-atlantic, just asking for local dyno locations, and got no response.
Old Mar 30, 2010 | 02:00 PM
bluemetals2k's Avatar
go get your afr checked again it might have adjusted ( dunno how ) itself or something and your running WAY to rich...but you really should have a wideband no joking around!!! When I was at stock boost my fpr was at LEAST if not more 1 full turn from the bottom.
Old Mar 30, 2010 | 02:14 PM
TheBigShow's Avatar
i was brainstorming on my way home from work today and got an idea. once i made it to the house, i got the s2 out of the garage, then went to the gas station. car felt like it was really limping at this point. put $10 in, and it ran fine! gauge was showing like 15% before, and it didn't really change afterwards. stopped, again, and filled it up this time. gauge went to full. car seemed to run better, too, but that might have been just in my head. over all, i managed to put over 11.5 gallons in. seems low not to get a fuel light.
needless to say, the shop is going to check the fuel pump install when i take it in. i feel better now.
Old Mar 30, 2010 | 02:36 PM
s2000Junky's Avatar
^^^ Did you replace just the pump and re use your OEM filter sock and housing? I ask because there has been problems with using some of the aftermarket fuel pump "kits" which supply their own housing and sock. The problem is the sock does not reach into the tank as far as oem, so you start to run out of gas with as much as 1/4 tank showing on your gage. Allot of guys found this out the hard way such as myself. This may be your problem, or one of them.
Old Mar 30, 2010 | 02:47 PM
TheBigShow's Avatar
i am pretty sure they didn't reuse anything oem.
Old Mar 30, 2010 | 04:11 PM
s2000Junky's Avatar
Ok, there is a very good chance that you are going to need to get a hold of the oem fuel pump assembly and sock, with any luck they still have it lying around to swap back. If you are going to have them help you look at this, mention this possibility or better yet log on and show them this thread. Good luck
Old Mar 30, 2010 | 05:15 PM
TheBigShow's Avatar
i have the oem. i'll ask them about it. thanks a lot.
Old Mar 30, 2010 | 05:58 PM
s2000Junky's Avatar
Yeah man no prob, hope this thread gives you enough to figure out your issues
UberDuper
Jan 15, 2016 10:23 PM
EOE
Sep 29, 2011 09:30 AM
pdexta
Oct 4, 2007 04:56 AM
ScottyBallistic
Oct 12, 2005 06:34 PM
Pakisho
Jun 2, 2003 10:02 AM
