is this a surge or what ?
Old Oct 11, 2012 | 09:49 AM
iAhmad's Avatar
Default is this a surge or what ?
hi everyone !
so i have my novi 1000 with a front mounted setup. and it has an HKS bov on it. i got it like that, i didn't do it myself !
anyway, i'm hearing some wired sound coming from the supercharger and it looks like it's not taking air properly !
here is a video i took of it !
http://www.youtube.com/watch?v=VDoql3_-fqY&feature=plcp
i did a little search and all i could understand is that it might be a compressor surge because of the HKS bov
and i'm supposed to get something called "bypass valve" because that's the best for supercharges !
if that's the case from where can i get a good bypass valve ?
if not, what do you guys think is the problem ?
any ideas ?
thanks !
Old Oct 11, 2012 | 04:25 PM
iAhmad's Avatar
Bump !
Old Oct 11, 2012 | 04:29 PM
apme123's Avatar
sounds like the bearing is on its way out
Old Oct 11, 2012 | 04:36 PM
flatrex's Avatar
Seems like a boost leak
Old Oct 11, 2012 | 07:35 PM
iAhmad's Avatar
so what should i do ??
Old Oct 12, 2012 | 12:46 PM
iAhmad's Avatar
Anybody any other ideas or suggestions ?
Old Oct 13, 2012 | 06:52 PM
Reapur's Avatar
Ditch the FMIC setup and find an aftercooler setup for the car. You'll make more power and be more reliable.
Old Oct 13, 2012 | 08:24 PM
starrman's Avatar
Not sure what that sound is...can you grab the end of the impeller shaft and see if it has any play? It very well could be a bearing saying good bye. If that is the case you can rebuild it or have someone else do it... Paxton no longer services the nv1000, they want you to buy a newer model. 928motorsports.com and superchargerrebuild.com both will do the deed for you...
with the fmic I think most people run a bov, vs the bypass valve that is stock on most of the kits that use an aftercooler. I don't know if a bad bov would cause surge, someone will jump in and school both of us.
Old Oct 13, 2012 | 11:07 PM
iAhmad's Avatar
when the the car is off the impeller shaft dose not move or anything, how can i know if it's a bearing going out ??
and how much you guys think it would cost to rebuild it ?
iAhmad
Dec 5, 2012 01:13 PM
broke 20
Nov 14, 2010 03:55 PM
woo
For Sale
May 2, 2010 11:58 PM
JayStyles662
Nov 12, 2006 10:54 AM
djmatix
Oct 31, 2005 05:06 AM
