Is this the Tach lead wire?
Old Oct 19, 2012 | 08:27 AM
JoeyBalls's Avatar
Default Is this the Tach lead wire?
Im installing a shift light (any suggestions of where to mount it, I hate the riceyness of it). I have seen the Modifry thread where you take off the Passenger panel thing underneath the airbag area, but I have read there is also a tach lead wire near the master cyclinder
I read something about a blue wire ( is it one of the blue ones in the top right picture)
[attachment=28996:image.jpg]
Old Oct 19, 2012 | 08:41 AM
herecomesboost's Avatar
The tach test connector is a single blue wire (ie. a wire leading to a two pin connector). It will be located by the fuse box on the drivers side. You can use that as a reference (signal wire).
Old Oct 19, 2012 | 09:17 AM
JoeyBalls's Avatar
Ok, I think I found it
[attachment=28997:image.jpg]
Old Oct 19, 2012 | 09:18 AM
Yeah. That's the wire you're looking for. Which tachometer did you end up buying?
Old Oct 19, 2012 | 09:35 AM
gettin it's Avatar
Are you installing a whole tach or a shift light? i was told you can install a led light and connect it to the aem. Is that true?
Old Oct 19, 2012 | 12:05 PM
JoeyBalls's Avatar
It's just a shift light
Old Oct 19, 2012 | 01:50 PM
GrandMasterKhan's Avatar
i would love to be able to wire something into that led on the gauge cluster. that would be awesome sneaky
Old Oct 19, 2012 | 01:54 PM
JoeyBalls's Avatar
easiest thing I ever did electrical wise , now I just have to set it perfectly. redline is 8700, should I set it to 8,300 ish?
Old Oct 19, 2012 | 02:01 PM
You can; just need to configure an available output accordingly
You can configure the MIL/CEL output as shift light in AEM
lecter255
Oct 5, 2009 03:26 PM
w00tw00t111
Apr 9, 2008 07:32 AM
QUIKAG
Aug 25, 2005 12:43 PM
kevsS2
Aug 24, 2004 12:19 AM
Mannn
Feb 5, 2004 06:48 AM
