Tail q50 spring for vortech, which one?
Old Jul 24, 2018 | 12:40 AM
e130dan's Avatar
Default Tail q50 spring for vortech, which one?
Hey, I have searched this on google all morning and there’s no recent posts and still few different answers.
I have vortech v2 that is gonna be rebuilt by vortech and upgraded to a si and probably get a 3.8” pulley.
Currently running 399hp atw. I’m buying a tial q50 bov and the place I’m buying says they only have the 2psi spring for a supercharged set up and not the 3psi.
so I looked up Too see what spring is best and I’ve found people say 2, 3, 6 and 10psi springs for supercharged but all old threads. Please can someone advise on what they use and what’s the most commonly used on supercharged now.
Thanks.
Old Jul 24, 2018 | 10:42 AM
AP1Chief's Avatar
Old Jul 24, 2018 | 05:14 PM
tkeyyy's Avatar
i had a 2psi spring on my v2, but changed to a 6psi after some time. even at 6psi, it wasn't enough for me. ended up getting a vortech race adjustable bypass valve and have it currently at 10psi and it's great.
with the 6psi, i felt like the throttle response was a bit slow vs the 10psi on the vortech bypass valve.
also, when my tuner was trying to tune with the 2psi and 6psi spring, they had to add more fuel to compensate all the boost pressure being pushed out of the BOV since the valve wouldn't close unless you're at 90-100% accel on your gas pedal.
Old Jul 24, 2018 | 10:09 PM
e130dan's Avatar
have you got a link please to show which vortech bov, is it the mondo one? Or maybe the 10psi spring in the tial is good a choice?
Old Jul 25, 2018 | 12:36 AM
AP1Chief's Avatar
You don't want it to close under slight part throttle, that's how you get compressor surge and damage the propeller.
Old Jul 25, 2018 | 01:45 PM
markforrester99's Avatar
I have always used the softest spring and never had an issue. If you use a really strong spring then the BOV/BYPASS valve will close at really light throttle openings. I cant see why a lighter spring would require more fuel on the map as all of the boost pressure would be dumped before it ever got near the inlet manifold. On a supercharged car you only really want boost when pushing on, the rest of the time you want it bypassing to aid fuel economy and wear on the charger. Another key thing with a bypass valve or BOV is making sure you use the right size vacuum line as this makes a big difference to the response of the valve especially when you lift off and you want the valve to open fully under vacuum.
Old Jul 25, 2018 | 07:28 PM
tkeyyy's Avatar
https://www.summitracing.com/parts/v...-064/overview/
Old Jul 25, 2018 | 09:51 PM
e130dan's Avatar
sorry, obviously I’m a compete newbie when it comes to this, what size vacuum line is usually used then? And also where’s the best place to take vaccume lines from? When the garage fitted my charger there was 2 vacuum lines I believe that we’re then t’d together and then to the bov. Think my tuner blocked one and just used one
Old Jul 25, 2018 | 11:17 PM
AP1Chief's Avatar
Larger the line the better.
Old Jul 26, 2018 | 11:20 PM
RolanTHUNDER's Avatar
Can a GReddy Type RZ BOV work with a Vortech V2 or does the spring have to be changed?
s2k402
Jun 7, 2014 08:29 AM
s2konroids
Jan 10, 2011 01:42 PM
Rdragon
Nov 9, 2010 06:30 PM
NATEWOOD07
Sep 5, 2010 12:10 PM
