In tank pump to surge tank - oem vs aftermarket
Hey guys,
I am planning to install my TTS supercharger soon. The kit comes with a Protec fuel pump which I guess flows 340. I purchased the SOS single pump wiring kit to wire it up
Along with that also I have purchased the radium auto surge tank with the walbro 450 pump and it comes assembled and with its wiring kit.
But I was wondering , Can I use OEM fuel pump and oem wiring as a LIFT PUMP to supply fuel to the radium auto surge tank instead of installing the aftermarket in tank fuel pump and wiring ?
Many thanks
Many thanks
I have a radium fuel surge tank with staged AEM 320lph pumps. I have been using the stock wiring for my lift pump without issues. The lift pump will operate at practically 0psi and should flow close to its max flow rate. You should ask radium about the lift pump or calculate how what minimum LPH is required for your power level and BSFC.
picco97
11-09-2016 09:33 PM
ScienceofSpeed
05-14-2014 04:49 PM
