Tapping the girdle for oil return, Problem fixed
Old Apr 11, 2011 | 06:43 PM
  #41
minitoyota's Avatar
male to male... 1/2 npt to -10an or -8an.. You can also use a 3/8npt if you want to use something smaller then 1/2". -12an is way to big for a drain line
Old Apr 11, 2011 | 06:48 PM
  #42
redboost10's Avatar
not really. it all depends on what space you have to work with. if the turbo is mounted low and the return does not have that much of a downhill slope, -12an can be beneficial and not considered overkill.
edit: i understand most are using smaller 62-67mm turbos on here with -3an feed lines where -10 should be more than enough...so yes -12an is larger than needed.
levn
Mar 19, 2019 03:14 PM
niccuhles
Apr 10, 2013 02:13 AM
TerminatioN
Apr 14, 2010 08:53 AM
NightStalker
May 30, 2005 09:19 PM
BBY2KS2K
Apr 23, 2003 04:03 PM
