Think I bought a messed up s2000
Originally Posted by ueat1023,Oct 16 2010, 06:48 PM
Well its not a gt40 I have a 60-1 Kinda in between a gt30 and gt35 Mine's is way bigger!
Do you have any more clear or closser pic of the engine bay?
Check all the bolt and look at the wastegate and bolts on it?
THIS HAPPENED TO A FELLOW BOOSTED CAR HERE IN VANCOUVER. HE TRIED EVERYTHING FROM COIL PACKS, SPARK PLUGS LIST GOES ON... IT WAS A CLOGGED CAT !!!!!!!! IF ITS STOCK OR HIGH FLOW TRY A STRAIT PIPE.
Originally Posted by Muscle Cars Blow,Oct 16 2010, 08:18 PM
I like your caps. I'm running a 3 inch single with a cut out. No cat. Anybody know if there is a tool or device to test if your pistons are blown?
Originally Posted by Muscle Cars Blow,Oct 16 2010, 02:01 PM
Im being told the turbo is a SC61. Dunno if that's a custom turbo or what.
I hope this dude didn't dump a big problem in your lap.
you are going to have to look through alot of things to find out what may be wrong but start with the map sensor and if they truly are running off of the stock map sensor, why in the hell did he run an aem series 2 and cheap out with the map sensor. tuner toys makes a nice attachment so that you can run an aem map sensor in the oem spot.
good luck finding the issue/s
