Think I bought a messed up s2000
Old Oct 16, 2010 | 11:30 AM
  #21
Suzuka_Joe's Avatar
I just have a small air filter from Autozone on mine
Old Oct 16, 2010 | 11:47 AM
  #22
Angerman's Avatar
Mitch, we need to take a video soon of the car. Maybe do it tomorrow afternoon before you go to work.
Old Oct 16, 2010 | 12:42 PM
  #23
Muscle Cars Blow's Avatar
Gonna take it to Bennys and see what problems we can eliminate. Maybe Wednesday morning we can do all this.
Old Oct 16, 2010 | 12:44 PM
  #24
Angerman's Avatar
Maybe, have to give him a call
Old Oct 16, 2010 | 12:51 PM
  #25
jared50438's Avatar
what kind of map sensor is on the car? they may just have the stock on on the throttle body there just to plug the hole, but you have to have a map sensor some place, probably a gm 3 bar need to find that, make sure its plugged in.
the white sensor is your intake temp sensor.
the black one in the throttle body is your stock map sensor
everything else is okay.. ish.
and thats not a gt40. sorry.
Old Oct 16, 2010 | 01:04 PM
  #26
Ok I'll poke around for more info. What turbo is it?
Old Oct 16, 2010 | 01:28 PM
  #27
jared50438's Avatar
couldnt tell ya without looking at a/r's and wheel sizing.
can you lower the boost at all? to just wastegate pressure? hook the wastegate right to the vaccum and bypass the boost controller. start with that and see what happens, any check engine lights?
Old Oct 16, 2010 | 01:38 PM
  #28
No check engine lights, abd it's on the lowest setting. Which I was told is 13 psi, bit could be wrong info as well. I'll do what you just suggested after my work week. The car runs fine just cruising and not doggin on it. I'm burning oil for sure by the signs of all the white smoke. Could the turbo be leaking? I'm no turbo expert, I believe I'm in over my head with this one. Might have to part the car out if problems keep popping up.
Old Oct 16, 2010 | 01:54 PM
  #29
jared50438's Avatar
dont part it out just learn what you need to and replace the turbo. check for shaft play and oil inside the compressor and exhaust housing
Old Oct 16, 2010 | 02:01 PM
  #30
Im being told the turbo is a SC61. Dunno if that's a custom turbo or what.
