Thinkin about a 3mm HG and ARP studs..
Old Oct 1, 2010 | 07:15 AM
1SlowSi's Avatar
You can run a ton of boost, just make sure its a very good tuner, and installation of the ARP studs are on point
Depending on the efficiency of your manifold, with the stock HG you can run anywhere from 380-450 on 93, and with the 3mm you can probably get around 500ish safely. If its the inline pro manifold, most stay right at 380-400 and nothing more (10-12 psi).
Old Oct 1, 2010 | 07:16 AM
camuman's Avatar
Originally Posted by JoeyBalls,Oct 1 2010, 11:06 AM
I wonder if the One AEM HD Pump is enough power to suppley 4 of their smaller nozzles? Or maybe get two Kits and have each pump supple two nozzles? Some steel braided lines, this might be really clean and doable. I just don't want to spend any more money on this car
resist my friend. RESIST!
i cant wait to be turbo and just make whatever i can on pump piss. no more meth, no more water, no more dicking around with anything. just low boost and hi boost and both on pump.
Old Oct 1, 2010 | 09:02 AM
Corey Maurer's Avatar
If your running the same ccs over the 4 nozzles as you would with one large one.. then why would you need a bigger pump? or another?
Old Oct 1, 2010 | 09:03 AM
oh and im pretty sure I am making the trip to evans to take care of my tuning!
Old Oct 1, 2010 | 10:12 AM
305s2k's Avatar
If you decide to get a 3mm headgasket let me know I have a new one for sale
Old Oct 1, 2010 | 10:17 AM
I think I'm gonna stick with stock stuff.. I know with my meth setup I can crack 500WHP and thatll be fine with me until I get a built motor going! thanks for all the help guys!
Old Oct 1, 2010 | 11:16 AM
D1sclaimer's Avatar
You could do more than 500whp with meth, but if you're building the motor and just want this to be fun and last, around 500whp is a smart idea.
Old Oct 1, 2010 | 11:22 AM
I was thinking of tuning for 18-21psi on the stock block with meth.. and whatever horsepower it turns Ill be happy with.. think thats a safe plan?
Old Oct 1, 2010 | 11:28 AM
D1sclaimer's Avatar
Sounds perfectly safe with a good tuner.
siadam's Avatar
I'm right there with ya Joey in regards to the $$.
I wasn't going to try and make more power on my meth setup.
I wanted to can it @ 600whp on 93, with a 9:1 I feel thats "safe".
BUT, I did want 4 nozzles, only b/c I feel it would be more reliable b/c I know the same amount of methanol is going into each cylinder, that was really my only concern.
