Torque damper/SC compatibility
Old Mar 3, 2007 | 02:21 PM
Headchef's Avatar
Active Streak: 30 Days
Default Torque damper/SC compatibility
Please help if you have a comptech supercharger and have installed an engine torque damper. It looks like they use the same mounting bolt and site- are they compatible and does it interfer with the supercharger bracket? I need to know before ordering one. Yes I know there is debate over its value- but I'm only looking for bling and to lessen shifter vibration. Thanks for any help you can give me.
Old Mar 3, 2007 | 03:08 PM
S_NeWb's Avatar
signing up on this one. having the same problem, but the only difference is taht i have it on hand already
Old Mar 3, 2007 | 05:19 PM
Ustemuf's Avatar
you need to fabricate a new bracket, or modify the existing one.
Old Mar 3, 2007 | 06:52 PM
gomarlins3's Avatar
I believe ^ is correct.
Old Mar 3, 2007 | 06:57 PM
SOHCmyDOHC's Avatar
you check out the puddy mount? s2kpuddy I think is the SC name here. Not sure about SC'd but he may be able to fab something up for FI folks.
Old Mar 3, 2007 | 09:41 PM
TRBOKEV's Avatar
FYI A torque damper will give you a LOT MORE shifter vibration.
Old Mar 3, 2007 | 10:05 PM
sean2sean's Avatar
only if you set the preload too high. otherwise its fine.
s2konroids
Jan 3, 2011 11:49 AM
s2konroids
Mar 23, 2010 09:52 PM
ego
Nov 8, 2007 07:51 PM
WindchaserS2K
Dec 31, 2006 03:31 PM
rocketman
Feb 9, 2002 08:29 PM
